centering selected item in listbox
tropfen
i am selecting an item in a listbox. some times this item is only shown partly in the listbox (see picture). i am using LB_SETSEL in a win32 Environment.
is there a possibility to center the selected item? Only one item is selected.
Thanks in advance
Frank
IanH
("i am" == "the user is" or "my program is"?)
Perhaps use LB_SETTOPINDEX with an appropriate offset of items to get your desired item in the middle.
IanH
tropfen
Hello IanH,
during developing time
i am ==
a) writing the source code
b) starting the program
c) pressing the button
what means that 'some times' the computer might do what i have intended ;-)
LB_SETTOPINDEX works for me
Frank
IanH
The reason why I was asking for clarification about who or what was selecting the item is that a user is going to get pretty cranky pretty quickly if items in listboxes start jumping around whenever they change the selection directly in the listbox, as opposed to the selection being set by the program in response to non-user input or user actions remote from the listbox (perhaps selecting the item as part of the initialisation of the dialog box or as the result of clicking on a button elsewhere), where having the selected item appearing in the right spot makes a great deal of sense.
tropfen
the change of the selected item is caused be a user action searching for a certain entry in the listbox. Therefor jumping around is intended and hopefully accepted by the user.
Frank
