29632 Discussions
class bound function pointer inheritance
may_ka
Hi there
I am trying to have a type bound function pointer inherited downhill through the class hierachy.
an example would be:
Module Mod_Bla_1
  Type :: Bla_1
    Procedure(SubGlobal_1), Pointer :: fun=>null()
  contains
    Procedure, Pass, Public :: Init => SubInit
  End type Bla_1
  Abstract Interface
    Subroutine SubGlobal_1(this)
      Import Bla_1
      Class(Bla_1), Intent(InOut) :: this
    End Subroutine SubGlobal_1
  End Interface
  Private :: SubBla1, SubInit
contains
  Subroutine SubInit(this)
    this%fun=>SubBla1
  end Subroutine SubInit
  Subroutine SubBla1(this)
  End Subroutine SubBla1
End Module Mod_Bla_1
Module Mod_Bla_2
  use Mod_Bla_1
  Type, extends(Bla_1) :: Bla_2
  contains
  End type Bla_2
  Private :: SubBla2, SubInit
contains
    Class(Bla_2), Intent(InOut) :: this
    this%fun=>SubBla2
  Subroutine SubBla2(this)
  End Subroutine SubBla2
End Module Mod_Bla_2
Program Test
  use Mod_Bla_1
  use Mod_Bla_2
  Type(Bla_1) :: xb1
  Type(Bla_2) :: xb2
  call xb1%init()
  call xb2%init()
End Program Test
However this does not compile with error message:
The procedure pointer and the procedure target must have matching arguments.
this%fun=>SubBla2
That would require me to write a new pointer for every child class, which would require me to "invent" a naming hierachy in order get it compiled (e.g. "fun_class_bla_1", "fun_class_bla_2") etc.
Is there any chance to get the example working.
Thanks a lot
Cheers
FortranFan
may.ka wrote:
.. Is there any chance to get the example working...
To get the example compile and run with the least code change, you can modify the dummy argument of SubBla2 to be 'class(Bla_1'.  But then in order for SubBla2 to be useful, more work might be necessary in the form of "SELECT TYPE" construct.  You don't show what you are actually trying to achieve with the PROCEDURE POINTER component, there may be other design patterns that may work out better.
may_ka
what I am trying to achieve is that I have two type bound procedures (e.g. sub1 and sub2) bound to bla_1 which are used conditional on how bla_1 is initialized. Both routines are overwritten in bla_2. In order to avoid if-branches checking conditions about whether to call sub1 or sub2 (called from bla_1 or bla_2), I thought about using a procedure pointer which can be set appropriately when bla_1(or bla_2) is initialized (in a practical application it is not just sub 1 and 2,  it is sub 1 to 8).
FortranFan
may.ka wrote:
.. what I am trying to achieve is that I have two type bound procedures (e.g. sub1 and sub2) bound to bla_1 which are used conditional on how bla_1 is initialized. Both routines are overwritten in bla_2. In order to avoid if-branches checking conditions about whether to call sub1 or sub2 (called from bla_1 or bla_2), I thought about using a procedure pointer which can be set appropriately when bla_1(or bla_2) is initialized (in a practical application it is not just sub 1 and 2,  it is sub 1 to 8). ..
Some object-oriented design may be due for your application, if you haven't done so already.
Based on what you describe, one possibility is an ABSTRACT base class that has a public procedure pointer component, a DEFERRED Init procedure, DEFERRED TBPs of sub1 thru' N, concrete TBPs that mirror to each of these deferred procedures (e.g., base_sub1 for sub1, etc.), and a setter procedure for the procedure pointer component that points to one of these mirrors.  These mirror TBPs then simply invoke the corresponding deferred procedures e.g., base_sub1 will invoke sub1 and so forth.
The concrete extensions such as bla_1 and bla_2 then provide concrete implementations of DEFERRED TBPs (sub1 => sub1_bla_1, sub2 => sub2_bla_1, sub1 => sub1_bla_2, etc.) as well as the Init procedure; Init then sets up the procedure pointer by invoking the setter method of the ABSTRACT base type using whatever logic is relevant for that type.
It's up to you to decide if this is worth your effort.
may_ka
Hi FortranFan
I cannot get it to work (see code below). Why would I need a setter method instead of setting the pointer in init?? I am still getting the same compilaiton error: "The procedure pointer and the procedure target must have matching arguments.".
Thanks for any comments.
Cheers
Module Mod_Bla_0
  Type, Abstract :: Bla_0
    Procedure(SubIF), Public, Pointer :: fun=>null()
  contains
    Procedure(SubIF), Deferred, Pass, Public :: Bla1
    Procedure(SubIF), Deferred, Pass, Public :: Bla2
  End type Bla_0
  Abstract Interface
    Subroutine SubIF(this)
      Import Bla_0
      Class(Bla_0), Intent(Inout) :: this
    End Subroutine SubIF
  End Interface
End Module Mod_Bla_0
Module Mod_Bla_1
  use Mod_Bla_0
  Type, extends(Bla_0) :: Bla_1
  contains
    Procedure, Pass :: Bla1 => SubBla1
    Procedure, Pass :: Bla2 => SubBla2
  End type Bla_1
  Private :: SubBla1, SubBla2, SubInit
contains
    this%fun=>SubBla1
Module Mod_Bla_2
  use Mod_Bla_1
  contains
  End type Bla_2
contains
    !!this%fun=>this%SubBla1
Program Test
  use Mod_Bla_1
  use Mod_Bla_2
  Type(Bla_1) :: xb1
  Type(Bla_2) :: xb2
  call xb1%init()
  call xb2%init()
End Program Test
FortranFan
may.ka wrote:
.. I cannot get it to work (see code below). Why would I need a setter method instead of setting the pointer in init?? ..
See below.  Notice my earlier comment about mirror TBPs in the abstract type.  As to the "setter" method, the rationale for my suggestion is the OO concept of encapsulation.  It's bad enough that Fortran only offers PRIVATE/PUBLIC attributes for MODULE entities and it misses on what I think is an essential third category of "INTERNAL" for extension types; this forces one to make public things that are better kept private to the type and its children; if I had a need to do something like what you are trying, I would prefer not to expose the "wiring" for procedure pointer FUN and thus keep the mirror TBPs private.  Hence the setter method.
You need to decide whether something like this is worth the effort in your actual application; OO is neat but as you know it can require more infrastructure type of code and there can be added complexity associated with it, as seen here.
(By the way, the code below follows some stylistic patterns that I like but which differ from yours)
module Mod_Bla_0
   implicit none
   private
   type, abstract, public :: Bla_0
      private
      procedure(Ifun), public, pointer :: fun => null()
   contains
      private
      procedure, pass(this) :: Base_Bla1  ! "private" mirror procedures to serve as
      procedure, pass(this) :: Base_Bla2  ! pointers to the actual ones
      procedure(Ifun), deferred, pass(this), public :: Bla1
      procedure(Ifun), deferred, pass(this), public :: Bla2
      procedure(IInit), deferred, pass(this), public :: Init ! this will force extension types to implement Init
      procedure, pass(this), public :: SetFun  ! "setter" method for OO encapsulation concept
   end type Bla_0
   abstract interface
      subroutine Ifun(this)
         import :: Bla_0
         class(Bla_0), intent(inout) :: this
      end subroutine Ifun
      subroutine IInit(this) ! separate interface because this might have different
                             ! arguments than Ifun
         import :: Bla_0
      end subroutine IInit
   end interface
contains
   subroutine Base_Bla1(this)
      ! invocation of the actual implementation of Bla1
      call this%Bla1()
      return
   end subroutine Base_Bla1
   subroutine Base_Bla2(this)
      ! invocation of the actual implementation of Bla2
      call this%Bla2()
      return
   end subroutine Base_Bla2
   subroutine SetFun(this, key)
      integer, intent(in)         :: key   ! some data to set 'fun' procedure pointer
                                           ! shown here as an integer key
      select case ( key )
         case ( 1 )
            this%fun => Base_Bla1
         case ( 2 )
            this%fun => Base_Bla2
         case default
            ! error handling elided
      end select
      return
   end subroutine SetFun
end module Mod_Bla_0
module Mod_Bla_1
   use Mod_Bla_0, only : Bla_0
   implicit none
   private
   type, extends(Bla_0), public :: Bla_1
      private
      character(len=16) :: m_s = "Bla_1 says Hello"
   contains
      private
      procedure, pass(this), public :: Init => SubInit
      procedure, pass(this), public :: Bla1 => SubBla1
      procedure, pass(this), public :: Bla2 => SubBla2
   end type Bla_1
contains
   subroutine SubInit(this)
      class(Bla_1), intent(inout) :: this
      ! logic to set "fun" goes here
      call this%SetFun( 1 )
      return
   end subroutine SubInit
   subroutine SubBla1(this)
      print *, "SubBla1: ", this%m_s
      return
   end subroutine SubBla1
   subroutine SubBla2(this)
      print *, "SubBla2: ", this%m_s
      return
   end subroutine SubBla2
end module Mod_Bla_1
module Mod_Bla_2
   implicit none
   private
   type, extends(Bla_0), public :: Bla_2
      private
      character(len=16) :: m_s = "Bla_2 says Hello"
   contains
      private
   end type Bla_2
contains
      class(Bla_2), intent(inout) :: this
      call this%SetFun( 2 )
      return
      return
      return
end module Mod_Bla_2
program Test
   use Mod_Bla_1, only : Bla_1
   use Mod_Bla_2, only : Bla_2
   implicit none
   type(Bla_1) :: xb1
   type(Bla_2) :: xb2
   call xb1%init()
   call xb1%fun()
   call xb2%init()
   call xb2%fun()
   stop
end program Test
Upon execution of code compiled with Intel Fortran compiler 17, update 1:
 SubBla1: Bla_1 says Hello
 SubBla2: Bla_2 says Hello
