codecov, .F files and .f90 files
Martin_C_
I use ifort 8.0 and have many #ifdef...#endif's (thousands) in the .F files used to compile/exclude large sections of code. Is there a way collate runs from various -Dxxx options usedinto one output from codecov?
Martin_C_
I upgraded to ifort v9.0 and found the following bug in profmerge.
The source directory is coded to be the directory where the source was compiled from, not the directory the source is in.
In addition, -src_old / -src_new does not change it to something different.
After surfing the forum for profmerge, I see others have similar problems.
I cannot get into Premier Support so I put the bug it here.
Make a directory for projects
Make a sub-directory in it called Source
In the Source directory enter the code:
PROGRAM ProfBug
write(*,*) "Compile this with:"
write(*,*) "ifort -fpp -prof_genx -qp -p -g Source/profbugger.F"
write(*,*) "from a directory above the source file."
if (.true.) then
write(*,*) "Run the code a.out"
else
write(*,*) "This is line 3"
endif
call other
write(*,*) "Look at the dyn file and you will see the source"
write(*,*) "listed wrong"
end
subroutine other
integer I
do I = 1,3
write(*,*) "I: ", I
end do
return
end subroutine
Move up one directory and compile and profmerge:
$ ifort -fpp -prof_genx -qp -p -g Source/profbugger.F
$ a.out
Compile this with:
Run the code a.out
I: 1
I: 2
I: 3
listed wrong
[mjcrawf@crater projects]$ profmerge
profmerge: merging dynamic file: ./4489b960_17385.dyn
[mjcrawf@crater projects]$ codecov
Intel C++/Fortran Compiler code-coverage tool for 32-bit applications, Version 9.0 Build 20050430Z Package ID: l_fc_p_9.0.021
Copyright (C) 1985-2005 Intel Corporation. All rights reserved.
Warning - File /chome/mjcrawf/projects/profbugger.F not found!
50% .. 100%
Also try:
$ profmerge -src_old /chome/mjcrawf/projects -src_new /chome/mjcrawf/projects/Source
profmerge: DPI Source Relocation:
profmerge: old source dir = /chome/mjcrawf/projects
profmerge: new source dir = /chome/mjcrawf/projects/Source
profmerge: relocated 2 of 2 source routines
50% .. 100%
Any suggestions???
Vital Info:
Intel Fortran compiler for Linux
ifort -v
Version 9.0
Linux version 2.4.21-40.ELsmp (bhcompile@hs20-bc1-1.build.redhat.com) (gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-54)) #1 SMP Thu Feb 2 22:14:12 EST 2006
glibc-2.3.2-95.39
glibc-devel-2.3.2-95.39
glibc-common-2.3.2-95.39
glibc-headers-2.3.2-95.39
glibc-kernheaders-2.4-8.34.2
glibc-utils-2.3.2-95.39
glibc-profile-2.3.2-95.39
gcc -v
Reading specs from /usr/local/lib/gcc/i686-pc-linux-gnu/3.4.1/specs
Configured with: ./configure : (reconfigured) ./configure
< font size="2">Thread model: posix
gcc version 3.4.1
Please report suspected bugs to Intel Premier Support. This forum is not a support channel.
Martin_C_
Back to the original question, but I upgraded to ifort 9.0, and ICC 9.1 and using profmerge l_cc_p_9.1.038 and codecov l_fc_p_9.0.021 with the same result:
I use ifort 9.0 and have many #ifdef...#endif's (thousands) in the .F files used to compile/exclude large sections of code. Is there a way collate runs from various -Dxxx options usedinto one output from codecov?
I realize these generate different .spi files but know of no way to collate the results correctly. I have 19 different compilation sets to merge for test coverage.
Martin
