colors in dialog
jenny_s
Hello!
Does anyone know if it is possible to change the color of the text in a dialogbox? I am using a Windows-projecttype. I would like to change the color of the text depending on the calculationresult.
Jugoslav_Dujic
Valued Contributor II
Is it created with DialogBox(Param) or with DLGMODAL?
jenny_s
I used DLGMODAL.
Jugoslav_Dujic
See my extended version of DFLOGM.
Jugoslav
jenny_s
Hi Jugoslav,
and thank you very much for helping me. I downloaded your testfile, and I tried to include your XFLOGM-file in my project, but I got a linking error. Have I done anything wrong?
error LNK2001: unresolved external symbol _DLGSETTITLE@12
Jugoslav_Dujic
No you didn't. XFLOGM is based on DFLOGM from CVF 6.0; I didn't manage to keep it up to date with Compaq's additions in the meantime (there aren't many, but DlgSetTitle and ActiveX support are the most important). Thus, the versions "diverged".
Guess I'll add DlgSetTitle support soon; in the meantime, the workaround is to use a dialog-initialization callback:
i = DlgSetSub(dlg, IDD_DIALOG1, SetDlgTitle)
subroutine SetDlgTitle(Dlg,ID,iEvent)
use dflogm
use dfwin, only: SetWindowText
type(Dialog):: Dlg
integer::      id, iEvent, i
i = SetWindowText(Dlg%hWnd, "Your Dialog Title"C)
end subroutine SetDlgTitle
Sorry for the inconvenience.
Jugoslav
jenny_s
Dear Jugoslav,
Thank you very much for your help. It is now working perfectly.
// Jenny
