29641 Discussions
command not recognized when setting up Intel MPI Library
zhzhu1218
I used to work with MPI codes using Intel Parallel Studio + VS 2019 + Fortran, and just updated to openAPI + VS 2022 + Fortran. When following the guide here (https://www.intel.com/content/www/us/en/docs/mpi-library/get-started-guide-windows/2021-6/overview.html) to set up the updated Intel MPI Library, I get through the first two steps (hydra_service -install; hydra_service -start). But when I key in mpiexec -register, the command prompt pops out '-register' is not recognized as an internal or external command, operable program, or batch file.
Am I making a silly mistake here?
Thanks!
Ron_Green
I think that documentation may be out of date.  My research shows that you should no longer need to do that -register step to enter your username/password credentials.
Try running MPI jobs.  It should work without the -register step/
zhzhu1218
Thanks Ron (truly appreciate your help so far with the multiple questions I've been facing when setting things up)! I tried running a simple hello world MPI job, but somehow it only runs with one thread (see first attached image for the result) despite me specifying the program to use 4 threads in the command arguments (as shown in the 2nd attached image). Any idea why this is happening?
zhzhu1218
ps. Here's the relevant part of the program I'm running
