compatible mpi libraries
twong
Can anyone recommend an MPI library that will be compatible with Intel Fortran?
TimP
In case my previous reply doesn't get posted, would you care to refine your question? Do you have an architecture and OS in mind? Interconnect? Size of cluster?
twong
Sorry, I should have been more specific.
I'm interested in using the MPI on a Windows XP system (Intel Pentium IV processors) for a small number of processors (from 2 on a Xeon chip to a small cluster of 8 to 16 processors perhaps using a Gigabit switch).
Terry
TimP
One more try to post response:
Argonne MPICH continues in use for Windows clusters up to 8 CPUs. It was built with CVF, continues to work when linked with Intel Fortran, although no longer supported. I heard the developers went to work for Verari. Clusters of 16 Windows CPUs are more often run with a master node running Samba (not Windows), partly due to the high cost of Windows Server.
Rumors of other developments are heard, but nothing definite yet.
