compilation aborted for ... (code 3)
mohanmuthu
新分销商 I
1,311 次查看
I am trying to migrate from CVF 6.6 to ifort 9.1, whereI used "Intel Fortran Compiler for Intel EM64T-based applications, Version 9.1Build 20060323 Package ID: l_fc_p_9.1.032" to compile my codes. But forfew files, I get following error.
fortcom: Severe: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
Can anyone help me to find right compiler options to trace the location/cause of error in ifort 9.1?
Mohan
0 项奖励
2 回复数
mohanmuthu
新分销商 I
1,311 次查看
Two additional info:
I use command prompt to compile. "ifort -c *.f90".
I compile in GNU/Linux 2.6.18-164.el5, x86_64
I picked one file, whichgave this error and did some testing. It had 5 subroutines, and started compiling one at a time (deleting all others) and found compiling. When I kept more than one subroutine, then it posed the same error.
I could compile the whole code and get the .exe file in windows (ifort 9.1.037). So, I think, code is goodbutI miss somethingin getting toLinux.
Unfortunately, I could not share my code.
0 项奖励
Arjen_Markus
名誉分销商 II
1,311 次查看
You will have to upgrade your compiler - version 9.1 is very old. The current version is 12.1
The error you are running into now is very likely fixed in a later version.
Arjen
0 项奖励
回复
