compilation order dependency?
Jim_Vickroy
I am usingIntel Visual Fortran Compiler XE 12.0.3.175 [IA-32].
I have a (simplified), three-file, Microsoft Visual Studio 2008 Project that generates compilation errors after "Clean Solution" followed by "Build". The compilation errors appear to arise because a module (in one file) "uses" a module (in a second file) that has yet to be compiled.
All modules, in each file, individually compile without errors provided dependencies are compiled first.
I did not see how to attach a ZIP archive of the Project to this posting.
I would appreciate feedback on what my mistake is (and how to attach a file to a posting).
Some things to try:
1. Remove the files from the project and re-add them.
2. Split the files into individual files per module.
For attaching files, see link in my signature below or in the "Useful Links" section of the main forum listing.
Jim_Vickroy
Thanks, Steve. I beleive a ZIP file is now available. -- jv
Jim_Vickroy
I believe the URL ishttp://software.intel.com/file/37601. -- jv
I tried building this in 12.0.4 and had no problems.
Jim_Vickroy
Thanks for trying this.
Here is my build log:
[bash]1>------ Build started: Project: Solar Thematic Maps, Configuration: Release Win32 ------
1>Compiling with Intel Visual Fortran Compiler XE 12.0.3.175 [IA-32]...
1>globals.f90
1>files.f90
1>C:Documents and Settingsjim.vickroyMy DocumentsVisual Studio 2008ProjectsSolar Thematic MapsSolar Thematic Mapsfiles.f90(87): error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [ERROR_COMPONENT]
1>C:Documents and Settingsjim.vickroyMy DocumentsVisual Studio 2008ProjectsSolar Thematic MapsSolar Thematic Mapsfiles.f90(114): error #6404: This name does not have a type, and must have an explicit type.   [IS_ERROR]
1>C:Documents and Settingsjim.vickroyMy DocumentsVisual Studio 2008ProjectsSolar Thematic MapsSolar Thematic Mapsfiles.f90(114): error #6341: A logical data type is required in this context.   [IS_ERROR]
1>C:Documents and Settingsjim.vickroyMy DocumentsVisual Studio 2008ProjectsSolar Thematic MapsSolar Thematic Mapsfiles.f90(133): error #6404: This name does not have a type, and must have an explicit type.   [IS_ERROR]
1>C:Documents and Settingsjim.vickroyMy DocumentsVisual Studio 2008ProjectsSolar Thematic MapsSolar Thematic Mapsfiles.f90(133): error #6341: A logical data type is required in this context.   [IS_ERROR]
1>C:Documents and Settingsjim.vickroyMy DocumentsVisual Studio 2008ProjectsSolar Thematic MapsSolar Thematic Mapsfiles.f90(146): error #6341: A logical data type is required in this context.   [IS_ERROR]
1>C:Documents and Settingsjim.vickroyMy DocumentsVisual Studio 2008ProjectsSolar Thematic MapsSolar Thematic Mapsfiles.f90(157): error #6404: This name does not have a type, and must have an explicit type.   [IS_ERROR]
1>C:Documents and Settingsjim.vickroyMy DocumentsVisual Studio 2008ProjectsSolar Thematic MapsSolar Thematic Mapsfiles.f90(172): error #6404: This name does not have a type, and must have an explicit type.   [IS_ERROR]
1>C:Documents and Settingsjim.vickroyMy DocumentsVisual Studio 2008ProjectsSolar Thematic MapsSolar Thematic Mapsfiles.f90(172): error #6341: A logical data type is required in this context.   [IS_ERROR]
1>compilation aborted for C:Documents and Settingsjim.vickroyMy DocumentsVisual Studio 2008ProjectsSolar Thematic MapsSolar Thematic Mapsfiles.f90 (code 1)
1>
1>Build log written to  "file://C:Documents and Settingsjim.vickroyMy DocumentsVisual Studio 2008ProjectsSolar Thematic MapsSolar Thematic MapsReleaseBuildLog.htm"
1>Solar Thematic Maps - 10 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
[/bash]
Some things to try:
Jim_Vickroy
Thanks again Steve.
Since this may be an error in compiler version 12.0.3.175, I'll submit a request to upgrade to version 12.0.4.
I have (partially) tried your first suggestion; I will revisit that.
Moving each module into a separate file (suggestion 2) seems unappealing to me, but if I have no other short term option I will try that also.
Jim_Vickroy
Suggestion 1 (remove/re-add source files to Visual Studio Project) worked !
I do not know why this worked nor which component (Fortran compiler, Visual Studio) was the source of the error.
-- jv
Well, it's not the compiler, but might be the Fortran integration into VS. I'll ask the integration developers about it - yours is not the first complaint about this I have seen.
