29641 Discussions
compile release version by Intel Fortran Compiler
PF59
I compiled and generated an executable file using the Intel Fortran
Compiler.  I was able to run the executable file alone on my machine
(compiled the code). However, I sent the code to my colleague on her
machine, she got the following error messages when she execute the .exe
file:
"The code execution cannot proceed because libmmd.dll was not found.
Reinstalling the program may fix this problem."
"The code execution cannot proceed because svml_dispmd.dl was not found.
"The code execution cannot proceed because libifcoremd.dll was not found.
I appreciate any help from any experts.
PF59
PF59
Steve,  It works.  I chose the alternate solution by choosing the Multithreaded and recompiled and the it works.  Thanks!!!
PF59
Steve_Lionel
Best solution - have your colleague install the redistributable package linked here.
Alternate solution - change your project property Fortran > Libraries > Use RunTime Library to "Multithreaded (/MT)", rebuild, and send the new EXE.
PF59
PF59
