compiler error in associate statement
Juan_Pablo_S_1
I get an internal compiler error with the following code.
[fortran]
program main
implicit none
integer,dimension(3) :: a
integer,dimension(4,4) :: b
a=(/1,2,4/)
associate(p=>b(:,a))
end associate
end program[/fortran]
On the other hand, I get no compilation errors with this other code:
[fortran]program main
implicit none
associate(p=>b(:,1:2:4))
end associate
What am I missing here?*
* compiled with ifort version 13.0.1 under linux mint 14
Steven_L_Intel1
An internal compiler error is always a compiler bug. Thanks for the short example - I will send this to the developers.
The issue ID is DPD200240855. You probably already know this, but in an ASSOCIATE constructor when the selector is an array with a vector subscript, you cannot assign to or otherwise "define" the associate-name. Your example doesn't do this (indeed it doesn't do anything inside the construct), but I figured I'd mention it anyway.
Steven_L_Intel1
This has been fixed for a release later this year.
