compiler internal error
orlih
Hello.
My program compilation falls with a message "Compiler Internal Error" when I add a string
ALLOCATE( EF(NFP) )
to my program. How can I solve it?
Submit an issue to Intel Premier Support and attach a test program that shows the error. Support will analyze the cause for the failure and tell you if there is a workaround.
Internal Compiler Error is always a compiler bug and should be reported.
