29629 Discussions
compiler rejects Fortran source containing variable with name "SELECT"
mecej4
Here is a stripped down version of an example code from the MKL forum, see https://software.intel.com/en-us/forums/intel-math-kernel-library/topic/606702#comment-1856431 .
The 16.0.1 and 16.0.2 compilers give a syntax error on line 14. If the variable select is renamed to slct, the syntax error goes away. If the subscript expression (/1,2,4/) is replaced by the equivalent [1,2,4], the syntax error goes away.
program xhess
implicit none
integer, parameter :: dp=kind(0d0)
integer i,j,n
real(dp), allocatable :: h(:,:),hsav(:,:),wr(:),wi(:),vr(:,:)
logical, allocatable :: select(:)
read(*,*)          ! title line
read(*,*) n
allocate (h(n,n),hsav(n,n),wr(n),wi(n),select(n),vr(n,2))
read(*,*)((h(i,j),j=1,n),i=1,n)
hsav=h                                  ! save for use with hsein
select((/1,2,4/)) = .false.
select(3) = .true.
end program
Thanks - we'll check it out.
Issue ID is DPD200407999.
Fixed for the 17.0 release later this year. The fix is not in the current beta.
