compiling 32 bit sequentially on 64 OS
anand_b_
I want to compile staticaly a 32 bit source code sequentially on 64 bit OS (Ubuntu 14.04) using ifort V-16 (parallel)
pl give the detailed command
anand
Steven_L_Intel1
First, you need to make sure that the gcc 32-bit support is installed, as it is not by default on most 64-bit distributions. If you haven't done this, then the ifort install will warn you that no 32-bit support is provided. Once you have done that, reinstall and it should add the 32-bit support.
Then all you have to do is use the "ia32" parameter to the ifortvars.sh script rather than "intel64". For example:
source /opt/intel/ifortvars.sh ia32
Now just use the "ifort" command as usual.
TimP
In a previous thread, OP said MPI was wanted, along with a current version of psxe which doesn't include 32-bit MPI.
There was also a lot of confusion about what OP meant by sequential, with the OP continually setting -parallel and -mkl=parallel.
anand_b_
thanks Steve and Tim
my laptop shows gcc installed. it is in root directory    usr/lib/gcc$  and has following files/ directory
aotcompile.py  classfile.py  i686-linux-gnu  x86_64-linux-gnu
how do i ensure that is 32- bit.  my laptop has ubuntu 14.04.
2.   if i make changes in bash file and replace intel64 by ia32,  then if i put ifort -v on terminal, then it says ifort not found..what should i do then
thanks
anand
TimP
I'd suggest testing to see that you can run a program compiled by g++ -m32.
When you installed ifort or parallel studio, if ia32 is enabled in the install options, the installer should complain if anything is missing in the g++ -m32 installation.  I guess now it will default to ia32 disabled if it doesn't see a full g++ -m32 installation.
If you installed originally without the ia32 option, you would need to run the psxe installer again, modify the installation, adding ia32 option.
