compiling error
Rodolfo_Araya
when I compile the file test.f95:
program test
print*,'hello world'
end program test
using the comand:
ifort test.f95 -o test
I obtained the following message:
ipo: warning #11015: Warning unknown option -no_compact_unwind
ipo: warning #11009: file format not recognized for test.f95
ld: warning: in test.f95, file is not of required architecture
Undefined symbols:
"_MAIN__", referenced from:
_main in for_main.o
ld: symbol(s) not found
Everything is OK if I use gfortran.
I have a Mac OS X 10.6.3 with Intel Fortran compiler 11.1.084 (last release?) 64 bits.
I obtained the same with the 32 bits options.
Any idea on what is going on? a compiler bug? a problem with ld?
Many thanks in advance!!
Rodolfo
TimP
An FAQ. Few compilers consider .f95 as equivalent to .f90. It does provoke an amazing bunch of extra errors. Did you try naming your file .f90?
Rodolfo_Araya
It works!! renaming the file with .f90 instead of .f95 did the trick.
Thanks a lot for the tip!!
Rodolfo
