compiling problem (I'm new in Mac
ccors
hello
I'm new in Mac. I installed a demo version of Intel Fortran Compiler in mac os X leopard, I can't compile any program, not even the most simple:
program test
write(*,*) 'hello world'
end program
and the compiler shows this error:
ld: duplicate symbol _main in /Users/carloscorsi/Desktop/propedeutico/programacion/mar 26-05/ejercicio14/build/ejercicio14.build/Debug/ejercicio14.build/Objects-normal/i386/main.o and /opt/intel/Compiler/11.0/059/lib/for_main.o
could you please tell me how can I solve it?
thank you
Ron_Green
Quoting - ccors
hello
program test
end program
thank you
strange one. So you compile with:
ifort -o test test.f90
? How are you compiling and linking the program?
TimP
This is a common FAQ. As most Unix-like systems have a built-in "test" command, attempting to overload that name for your own unrelated purpose isn't recommended. This isn't the reason for your linker problem. When you get to running, you would be depending on your shell distinguishing "test" from "./test" et al.
ccors
Quoting - tim18
This is a common FAQ. As most Unix-like systems have a built-in "test" command, attempting to overload that name for your own unrelated purpose isn't recommended. This wouldn't necessarily explain a linker problem. When you get to running, you would be depending on your shell distinguishing "test" from "./test" et al.
I use Xcode to program and then clik "Build", I don't use the Terminal
Ron_Green
Quoting - ccors
did you read the section in the documentation, the User's Guide, chapter "Building Applications with the XCode IDE"?
Documenation in /opt/intel/Compiler/11.0/053/Documentation/compiler_f/compiler_documentation_f.htm
Open in Safari or Firefox and navigate to that chapter, it's under 'User Guide' -> 'Building Applications'
It sounds like you either have 2 main programs in the sources for the project OR somehow you have a main.c source added to the project.
ron
Kevin_D_Intel
You can try obtaining the Xcode Hello sample I provided under an earlier thread at:
http://software.intel.com/en-us/forums/showpost.php?p=76240
ccors
ok!
now it works!
thank you fortran masters!!
