controlling parallel port using CVF
debrown
Is there anyway to control the parallel port using CVF?
I would like to use the parallel port to sent TTL signals
to a relay--that is, I need to tell the individual data lines of the port to go high or low. There seems to be simple programs in Delphi and C, but, since I have CVF, I would like to use it. Thanks for any help,
--- DEBrown
You'd need to call a Win32 API routine directly. See the on-disk documentation under Platform SDK, Windows Base Services, Hardware.
Steve
