29391 Discussions
converting radix-specified constants
raov
CVF and IVF support the nonstandard Fortran 95 statement
integer, parameter :: i=#80000000
but several other compilers do not. Is there a standard F95 equivalent?Thanks.
TimP
z'80000000'
Shown as the preferred form in your IVF documentation.
The most common form since long before f90 standardized it:
http://csit1cwe.fsu.edu/extra_link/xlf/lr33.HTM
Mighty strange that the Compaq on-line document from 2001 doesn't even show the standard version.
david_jones
.... but did you look under "Hexadecimal Constants" ?
Tim, the standard syntax is described in the chapter with the rest of the constants. See here.
