corrupt PDB file
jmloriot
I have the following error, what can I do ?
Compiling with Intel(R) Visual Fortran Compiler 17.0.0.109 [IA-32]...
definitions_de_base.f90
error #31000: corrupt PDB file vc140.pdb; delete and rebuild; if problem persists, delete and try /Z7 instead
ifort: error #10298: problem during post processing of parallel object compilation
compilation aborted for C:\casal\definitions_de_base.f90 (code -1)
Delete the file with the .pdb file type in your project's Debug folder and rebuild the project.
jmloriot
Thank you Steve, your answers are always accurate and helpful.
I had deleted the prog_name.pdb but not vc.pdb
