creating 64bit appication
tropfen
i have a question about how to create a 64bit project.
i have win 7 64 bit and IVF 11.1.048 including VS2008 (installed as complete 32bit and 64bit)
i cannot find a way to create or change to a 64bit project/application.
what do i have to do?
Thanks in advance
Frank
Les_Neilson
Valued Contributor II
Quoting - tropfen
Thanks in advance
Frank
Project -> Properties -> Configuration Manager -> Solution Platform
Select New
Select x64 and you can if you wish copy the settings from an existing config (eg win32)
Les
