29641 Discussions
creating a tab control using CreateWindowEx
nandita
I'm trying to create a tab control in a Fortran Windows Application in CVF. Iused the following code inthe MainWndProc() function.
Code:
 type (T_INITCOMMONCONTROLSEX) iccex
 case(WM_CREATE)
    iccex%dwSize = sizeof(iccex)
       iccex%dwICC = ICC_TAB_CLASSES
    call initCommonControlsEx(iccex)
    hwndTab = CreateWindowEx(0, WC_TABCONTROL, ""C, &
     ior(WS_CHILD, IOR(WS_VISIBLE,TCS_MULTILINE)), 0, 0, 0, 0, hwnd, &
     IDC_TAB1, ghInstance, Null)
    MainWndProc = 0
    return
However I get the following error:
C:Documents and Settings gawadeMy DocumentsoVF est1 est1.f90(187) : Error: This name does not have a type, and must have an explicit type. [WC_TABCONTROL] hwndTab = CreateWindowEx(0, WC_TABCONTROL, ""C, & ----------------------------------------------^ Error executing df.exe.
I then tried to use some other common control windows classes in CreateWindowEx, some of them work and others don't.
Is there some other way to insert a tab control in the main window? I want to make something that looks like the Properties window.
nandita
Jugoslav_Dujic
Valued Contributor II
character(*), parameter:: WC_TABCONTROL = "systabcontrol32"C
unfortunately, for some reason, is not defined in CVF's DFWINTY.f90, but you can use the literal string instead.
Jugoslav
nandita
Yes, I figured that out. For some reason it is defined as
character*15, parameter :: TAB_CLASS_NAME = "SysTabControl32"C
But I still could't see the tab control when i start the application.
Finally I just inserted the tab control in a modeless dialog box that is created in WM_CREATE.
I don't like this too much. Is there a better way to do this?
Jugoslav_Dujic
In your posted code, Tab control's dimensions are zero -- does that explain why you don't see it :o) ? (Tip: you can use Spy++ application to examine hierarchy and properties of all windows in the system).
Otherwise, approaches with modeless child dialogs are frequently used for "property window" kinds of stuff, because they're simpler to design and maintain than a bunch of CreateWindows, but in your case you'd probably want the tab control as direct child of main window, and child dialogs as children of the tab control.
Jugoslav
nandita
silly me
it works now...thanks so much!
nandita
