cross-platform compilation
lori_burns
I've been using the Fortran compilers (9.0 & 9.1) on a RHEL3 itanium2 system and would like to run programs developed there on a department linux (Fedora Core) cluster composed of Pentium IV machines. As the cluster has no compilers, I want to compile for pentium on the itanium, but any processor-specific options I submit are discarded and thus the binary is created for itanium.
$ ifort -arch pn4 -static -o hellopentium6 hello.f
ifort: warning: target processor options not supported in this product
Is cross-platform not supported between the ia32, em64t, and ia64 compilers, or am I neglecting some aspect of the process? Thanks for your help.
Lori
Sorry, if you're on Itanium, you can compile for Itanium only. There are distinct compilers for each architecture. On IA-32 and Intel 64, it's possible to install both compilers (if you have the proper gcc environment) and do cross-compile, but this is not supported on Itanium.
There is a table in the Installation Guide and Release Notes that shows the supported combinations.
lori_burns
Alas, thanks for confirming that. I am chagrined to have missed the cross-compilation table in the short reference documents- I've been searching the manuals.
