Hello all,
When I define an elemental assignment for a derived type and use cshift for an array of this derived type
I get a strange output. It seems that the {cshift-assignment} "structure" doesn' t correctly replace the last
element with the first when the derived type's assignment is declared as elemental.
There are too possible workarounds. Either defining an intermediate array to store cshift or skipping the "elemental" keyword for theassignment.
I understand that cshift works without defining an assignment for the derived type shifted, however, I think that thisis not the purpose of defining an assignment.
Here is the code:
[fortran]module mytypes_witheq
type areal
real(kind(0.d0)) :: x
end type areal
interface assignment (=)
module procedure eqreals
end interface
contains
elemental subroutine eqreals(p1,p2) !<----- this causes a problem
!subroutine eqreals(p1,p2) ! <----- this seems to work fine
type(areal), intent(inout) :: p1
type(areal), intent(in) :: p2
p1%x=p2%x
end subroutine eqreals
end module mytypes_witheq
program test_shifts
use mytypes_witheq
type(areal), dimension(:), allocatable :: help
type(areal), dimension(:), allocatable :: poiarr
integer :: i , i1, alloc =3
allocate(poiarr(alloc),help(alloc))
do i=1, alloc
poiarr(i)%x = i
end do
print *, ' '
print *, ' No shift '
do i1=1,alloc
print *, poiarr(i1)
end do
print *, ' '
print *, ' An array of type a_real is used and changes after each cshift'
do i=1,alloc
print *, ' after ', i, 'shift(s)'
poiarr=cshift(poiarr,1)
do i1=1,alloc
print *, poiarr(i1)
end do
end do
print *, ' '
do i=1, alloc
poiarr(i)%x = i
help(i)%x = i
end do
print *, 'An intermediate array of the same type is used but does not change after each cshift'
do i=1,alloc
help=cshift(poiarr,i)
do i1=1,alloc
print *, help(i1)
end do
end do
end program test_shifts[/fortran]
The above code gives :
No shift
1.00000000000000
2.00000000000000
3.00000000000000
An array of type a real is used and changes after each cshift
after 1 shift(s)
2.00000000000000
3.00000000000000
2.00000000000000 ! <---- not expected
after 2 shift(s)
3.00000000000000
2.00000000000000
3.00000000000000 ! <---- not expected
after 3 shift(s)
2.00000000000000
3.00000000000000
shift
after 1 shift(s)
2.00000000000000
3.00000000000000
1.00000000000000
after 2 shift(s)
3.00000000000000
1.00000000000000
2.00000000000000
after 3 shift(s)
1.00000000000000
2.00000000000000
3.00000000000000
If the assignment is not declared as elemental, the output is correct.
Is this a bug ?
Please check it and let me know if you get the same error.
Thank you !
Note ::
ifort -V
Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.1 Build 20120612
Copyright (C) 1985-2012 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
I have also tested it using the latest windows ifort compiler and the same error appeared.
That bug has already been reported > 5 years ago. Progress on this issue seems to have been slow.
I tried the program with the current 12.1 compiler and can see the problem, but the compiler in the next major release (August-September) gets it right:
No shift
1.00000000000000
2.00000000000000
3.00000000000000
after 1 shift(s)
2.00000000000000
3.00000000000000
1.00000000000000
after 2 shift(s)
3.00000000000000
1.00000000000000
2.00000000000000
after 3 shift(s)
1.00000000000000
2.00000000000000
3.00000000000000
shift
after 1 shift(s)
2.00000000000000
3.00000000000000
1.00000000000000
after 2 shift(s)
3.00000000000000
1.00000000000000
2.00000000000000
after 3 shift(s)
1.00000000000000
2.00000000000000
3.00000000000000
I looked for issues reported against CSHIFT but the last one was closed in 2010 and isn't this problem. RO, do you have a pointer to a thread where this was reported?
No shift
1.00000000000000
2.00000000000000
3.00000000000000
after 1 shift(s)
2.00000000000000
3.00000000000000
1.00000000000000
after 2 shift(s)
3.00000000000000
1.00000000000000
2.00000000000000
after 3 shift(s)
1.00000000000000
2.00000000000000
3.00000000000000
shift
after 1 shift(s)
2.00000000000000
3.00000000000000
1.00000000000000
after 2 shift(s)
3.00000000000000
1.00000000000000
2.00000000000000
after 3 shift(s)
1.00000000000000
2.00000000000000
3.00000000000000
Many thanks Steve !!
