cygwin linking
jweyant74
1) How do I compile visual based fortran programs from cygwin command line?
2) What is the path for ifort?
TimP
Quoting - jweyant74
It requires all the paths normally set for ifort, so the simple way is still to open the ifort command prompt window. Then, if you wish to have cygwin available as well, run the same cygwin.bat command as you see in the cygwin shortcut. In order to avoid having the cygwin link take precedence over the Microsoft one, fill in the Microsoft linker directory path in ifort.cfg. All explained at greater length in past posts.
