29649 Discussions
debug variables in user-defined type in a module?
Li_Dong
Hi, all,
I'm using Intel Visual Fortran in Windows XP, and I wrote a program that has a module with user-defined type, like this
[plain]type cell
real(8) :: x_center
real(8) :: x_left
real(8) :: x_right
real(8) :: dx
real(8), allocatable :: u_left(:)
real(8), allocatable :: u_right(:)
real(8), allocatable :: q_mean(:)
real(8) :: q_left
real(8) :: q_right
real(8) :: integral_flux_left
real(8) :: integral_flux_right
real(8) :: fractional_flux_left
real(8) :: fractional_flux_right
character(10) :: reconstruction_type
real(8) :: slope
end type cell[/plain]
My problem is when I am debugging, I can't watch a variable in "cell" type!
Thanks for help!
DONG Li
Li_Dong
By the way, I can watch it in Linux.
ArturGuzik
Valued Contributor I
Quoting - dong_li_1985
which version do you use (on Windows). The derived type variables are visible in VS debugger in IVF version 11.X (and perhaps from 10 something, Steve will know the details). If you want to see the variables inside module then the "old" way of doing this was to type (in watch window)
Module_Name::variable_name
A.
Li_Dong
Quoting - ArturGuzik
A.
Hi, ArturGuzik,
I'm using 11.0.061. And I have tried with "Module_Name::variable_name" in watch window, it works! But need I do this everytime?
Thanks for replying!
ArturGuzik
Hi, ArturGuzik,
Well, I'm not sure now, but certainly Steve can provide definite answer to that. I have version 11.0.072 and everything works there, I mean, you just use cursor to get info (no typing needed). I recall that the improvements to the debugger (displayed symbols) were introduced "recently", although I'm a bit confused with all that versions, betas etc.
A.
I can't easily test right now using both an 11.0.074 compiler and 11.0.074 VS integration, but I do see that using 11.0.074 compiler and the 11.1 VS integration works - the module variable shows up under locals and I can watch it without naming the module. This requires that the module be USEd and the variable be referenced within the routine where I want to look at it. Otherwise, the modname::varname syntax is needed.
