29422 Discussions
debugger can't see host-associated vars in contained subroutines
martymike
I'm just beginning the process of converting from using CVF to IVF 9.1 with Studio 2005.net. I've built a combined C and Fortran project (Fortran main) and the program runs properly for all the tests I've conducted so far. While testing, though, I found that I cannot evaluate host-associated variables while in contained subroutines when stepping through the code in the debugger. I can't believe this is a real bug - it's probably just some setting somewhere, but I can't find it. Anybody know?
Unfortunately, this is a current restriction. We know about it and hope to resolve it in the near future. You may be able to use the stack frame pulldown to set the context back to the caller to view those variables.
gabriel_cavallaro
I just jump from CVF to IVF under visual studio .NET. I have the same problem (the variables that are passed to a subroutine appears in watch windows with dummy numbers. But the programs works well).
Is it fix now ? (do we need to install an update)
If it's not, can you explain more precisely the procedure you tell ?
Gabriel
I don't think the fix for this has been released yet. If you submit a problem report to Intel Premier Support, we may be able to get you an early copy of the fix.
The particular problem with viewing host-associated variables is understood but not yet fixed. Work is in progress on this. As a workaround you can either:
1) Use the "context" dropdipown in Visual Studio to set the context to the caller where the variable is declared, or
2) If it's a module variable, use the syntax modname::varname in a watch window to view the variable
This works in most cases. We apologize for the inconvenience and hope to fix this soon.
gabriel_cavallaro
Thanks for your help and fast reply.
jackosullivan1
Steve,
Has this been fixed in IVF 10.0?
Thanks and God bless!
jackosullivan
jackosullivan
I just noticed that Steve is on vacation...
Does anybody know if this has been fixed in IVF10?
Jeffrey_A_Intel
Things are better (we think) but there are still some problems to be fixed and work is on-going to fix them. In those cases where we still don't get it right, Steve's work-arounds a few lines up should help.
jackosullivan
Jeff,
Thanks for the quick reply and advice. I'm having trouble identifying what is meant by the "Context Dropdown" (using Visual Studio .NET 2003 Service Pack 1). I could find no reference to such in the Help. I was able to switch my way back and forth between the "contain"-ed subroutine and the "contain"-ing subroutine by using the "Call Stack" tab during Debugging. But that isa really tedious way to do things, especially when switching lines in the Call Stack causes the source view to switch to the calling line.
Have I been missing something?
Also, is there any way to sort the variables in the "Locals" window -- or some other window --that would let me locate the variable values quickly?
Thanks again for your help and God bless!
Jack O'Sullivan
Jeffrey_A_Intel
Sorry for the delay in replying; I'm on the road.
Yes, I believe Steve was referring to the Call Stack window. AndI know it's less than ideal; it's a work-around, not a solution. Be assured we wantthisfixed just as much as you do.
I don't know of any way to change the order in which Visual Studio displays variables in the Locals window. When I'm interested in just a few such variables, I use a Watch window.
jackosullivan1
Jeff,
Thanks very much.
I'll keep lighting those votive candles in front of St. Jude's statue that this problem gets fixed soon.("Saint for impossible causes", you know ;-)
God bless!
jack
gabriel_cavallaro
Can you tell me if it's now fix ?
Best,
Not yet, but it is being worked on. The problem is quite complex.
gabriel_cavallaro
Some news ?
Best,
News is the same, but there has been progress. I can't predict when a fix will appear.
