29652 Discussions
debugging Fortran DLL called from ASP.NET
Intel_C_Intel
I'm writing a Fortran DLL using the Intel Fortran Compiler. The DLL is being called from an ASP.NET form-based application (actually from the C# code-behind DLL). However, I cannot figure out how to use the integrated Intel debugger to step through my fortran code. Debugging a DLL appears to require an "application to start to initiate debugging". Since the DLL will be called by a running application (the local web server on my development machine), does anyone have any suggestions concerning how to configure the debugger so that I can step through my Fortran code? Debugging the ASP.NET code-behindDLL does not allow me to step into the Fortran DLL when it is called.
