29649 Discussions
default initializing variables (heap and stack) to 0
ifortuser
Hi, I am looking for a intel fortran compiler flag that would allow me to default initialize variables to 0 (or other values), these variables could be declared on the stack, the heap or allocated dynamically.  I didn't find anything myself from the compiler options.
program defaultinit
    real :: x
    real(:), allocatable :: y
    allocate(y(10))
end program
With the default initialization, I am hoping I could initialize x and y to 0 during run time without manually initializing them. Is this possible through compiler flags?
jimdempseyatthecove
Compiler option /Qzero
implicit initialization to zero of local scalar variables of intrinsic type INTEGER, REAL, COMPLEX, or LOGICAL that are saved and not initialized
Compiler option /Qinit:<keyword>
   enable/disable(DEFAULT) implicit initialization of local
The <keyword> specifies the initial value
   keywords: zero (same as /Qzero),
   snan (valid only for floating point variables),
   infinity, minus_infinity (valid only for floating point)
   tiny, minus_tiny (valid only for floating point)
   huge, minus_huge
   arrays
For allocatables use SOURCE with scalar
allocate(Y(10), SOURCE=0.0) ! or whatever value you want
Jim Dempsey
Steve_Lionel
Even better - don't do this, fix your code instead.
ifortuser
Thanks, this is to help to identify the bug in the code and fix the problem. Occasionally we have legacy code where someone forgot to default initialize variables and it's difficult to pinpoint where the problem is. Being able to default initialize variables to 0 or infinity will help us to figure out where the problem is.
Jim, the -init option looks like exactly what I need.
jimdempseyatthecove
Also consider using /Qtrapuv   trap uninitialized variables
And /RTCu report use of variable that was not initialized
And /check:uninit
And /check:bounds
Jim Dempsey
jimdempseyatthecove
Relying on default initialization will get you into trouble, either sooner or later. Explicitly perform your initialization.
Implicit initialization is .NOT. part of the Fortran standard.
And why would you presume 0/0.0 is the proper value for initialization?
Jim Dempsey
Steve_Lionel
Don't bother with /Qtrapuv - it doesn't do what it says in the manual. /check:uninit is what you should be using.
ifortuser
Great, thanks for all the input. We are not trying to sweep something under the rug, this will help us to debug  problems caused by uninitialized value.
jimdempseyatthecove
While you are at it, add
  /gen-interfaces /warn:all
Note, warnings may be errors (in particular interface warnings).
Consider each warning before you dismiss it.
Jim Dempsey
Steve_Lionel
You don't need /gen-interface anymore if /warn:interfaces is enabled (or /warn:all).
I also like to do a build with /stand (standards checking) to identify extensions I hadn't intended to use - these can sometimes lead to unanticipated results.
