define makefile for compile
hamid_mosaddeghi
Hi Dears
I need to compile this code but how define make file in rdf subdirectory?
thanks
Best Regards.
TimP
It may be sufficient to replace g77 (2 places) by ifort, possibly adding -fp-model source to FFLAGS. If the application depends on disabling optimization (as seems to have been recommended for cygwin), use -O0 rather than -fp-model source
Was that your question?
hamid_mosaddeghi
thanks
but I replace g77 with ifort but I get error for latest section "hread.f,...."
I get "NO Target ...."
please check it.
Best!
TimP
This would seem to indicate that you didn't set up your directory structure consistent with the (unusually structured) makefile. What does
less ../FORT/hread.f
give you, from the directory where you start make?
hamid_mosaddeghi
Dear TimP
do you mean I remove ../Fort/heard.f from make file?
I set directory of heard.f and other but I get error , please check it and compile it once.
