29649 Discussions
demo code specifically dll_shared_data
steve_k_3
I recently downloaded composer edition XE 2015 update 2 for trial and I am trying to get 2 programs to share data, I have tried several things that I saw online to accomplish this, the 2 programs both will link but they do not share the data (i.e. the variable has one value in one program and a different value in the other)... I specifically have been trying a dll and the !DEC$ ATTRIBUTES DLLEXPORT (and DLLIMPORT) method
I see there is a sample program called dll_shared_data taht is supposed to illustrate this functionality, but this solution does not appear to be included in what I downloaded... can anyone post this code snippet or tell me where it is available?
mecej4
If you installed into the default location, you will find C:\Program Files (x86)\Intel\Composer XE 2015\Samples\en_US\Fortran\DLL.zip. Extract that file into a working directory, and you will find two subdirectories, one of which is DLL\DLL_Shared_Data. This is the example you sought.
