29376 Discussions
derived type as a PRIVATE variable in parallel region - ifort crashes!
butette
So I have a simple program that allocate a derived type as a PRIVATE variable in a parallel region.
When I compile it with ifort 12.0.4, the compiler crashes with an internal error. As far as I know what I am
doing is legal, and the IBM xlf2003 compiler handles it without any problem.
Attached is the small example that illustrate the problem.
>cat omp_private_type.F90
module junk_mod
type junk
integer :: threadid=-1
contains
procedure setID
procedure getID
end type junk
contains
subroutine setID( this, id )
class(junk) :: this
integer :: id
this%threadid = id
end subroutine setID
function getID( this ) result( id )
class(junk) :: this
integer :: id
id = this%threadid
end function getID
end module junk_mod
program test
use omp_lib
use junk_mod
type(junk), allocatable :: junktype
integer nthreads
!$omp parallel default(shared), private(junktype,id,idjunk)
allocate(junktype)
id=omp_get_thread_num()
call junktype%setid(id)
idjunk=junktype%getid()
print *, id, idjunk
deallocate(junktype)
!$omp end parallel
end program test
>ifort -v
Version 12.0.4
>ifort -openmp omp_private_type.F90
0_1855
omp_private_type.F90(27): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for omp_private_type.F90 (code 1)
Thanks for the nice example. I can reproduce it in 12.0.4 but not in an engineering version planned for release later this year. One doesn't even have to do anything inside the parallel region, and the type-bound procedures are not relevant - just declaring the allocatable derived type and having a parallel region is enough.
