29648 Discussions
determining if string is valid numerical type
tracyx
I have a string that I want to convert into a numerical type (integer or real). Is there an elegant way to determine whether the string contains a valid numerical type, or is it necessary to loop over all the characters to determine this?
Thanks, Tracy
Quoting - anthonyrichards
Use internal READ and use ERR= branching until you get no error. e.g.
READ(STRING,ERR=9999, *) realvariable
READ(STRING,ERR=9999, *) integervariable
Perhaps you meant READ(STRING,*,ERR=9999)? In any event, I do not recommend using list-directed reads for doing input validation. It is much more liberal about what it will consider valid input than is wanted here. For example, it will accept a comma or a slash. I would suggest an explicit format with an In or Gn.0 format as needed, where n is the width of the string.
anthonyrichards
New Contributor III
Quoting - tracyx
Thanks, Tracy
tracyx
Thank you both, that is perfect for my needs.
Kind regards, Tracy
jimdempseyatthecove
Tracy,
In your debug build, consider not only using the Gn.0 or other format specifier, but also include your own sanity check for spurious input. Then throw everything imagineable at the routine for testing. A false positive is not an indication that the data is correct. And, remember actual input data may be stranger than you can imagine.
Jim Dempsey
rase
John Burkardt maintains various libraries with Fortran source code, among them one called CHRPAK with routines for conversion of character strings and other string-related functions (http://people.sc.fsu.edu/~burkardt/f_src/chrpak/chrpak.html) . Maybe you can find there what you are looking for.
