determining the number of readed values
dnoack
初学者
1,727 次查看
in a text file each line contains an arbitrary number of values. I would like to read this file line by line and determining the number ofvalues in every line.
Does anyone know a simple method for this problem.
Thanx in advance.
dnoack
0 项奖励
2 回复数
jimdempseyatthecove
名誉分销商 III
1,727 次查看
Look in the documentation regarding nonadvancing I/O (ADVANCE='NO')and use of EOR=nnn or IOSTAT=iStatus.
Or, depending on your data, you could preload your input arraywith a value that will never be in your input. After reading a record check for your preload value.
Jim Dempsey
0 项奖励
greldak
初学者
1,727 次查看
Assuming your lines are of a reasonable length I'd read the line into a string long enough to hold your longest expected line
If you have no seperators the number of values is simply obtained from the length of the string trimmed to remove white space at the end divided by the size of your value.
If you have seperators - commas, spaces whatever count them, the number of values will be the same as your count if there is a seperator after the final value or 1 more if not
You can then use internal IO to convert obtain the values from the string
0 项奖励
回复
