29604 Discussions
dialog boxes - understanding required
michael_green
There is a lot I don't understand about WIN32, dialog boxes, and DFLOGM. I have a dialog box which has, among many other things, 3 pairs of radio buttons. The first of each pair is checked "group" and the second is not. If I use the following code in the dlg proc:
select case(message)
   case(WM_INITDIALOG)
      call CenterWindow(hDlg,GetWindow(hDlg,GW_OWNER))
      OverlayDlgProc = 1
      return
the dialog, and in particular, the radio buttons work fine, except that none of the radio buttons is on when the dialog first appears. However, with the following version:
use dflogm
implicit none
type (dialog) dlg
dlg.hwnd = hDlg
   case(WM_INITDIALOG)
      bret = DlgInit(IDD_overlay,dlg)
      bret = DlgSet(dlg,IDC_optheme,'qtest')
      OverlayDlgProc = 1
      return
the radio buttons work perfectly. This surprises me because the statement
is quite irrelevant as far as the radio buttons are concerned, yet it appears necessary, as do the other extra bits and pieces. Please could someone explain what's going on here.
With many thanks
Mike
Jugoslav_Dujic
Valued Contributor II
You're toying with fire here. I can tell you what's going on, but that's not the way to do it. You're loading the Dlg structure to memory using DlgInit, and then fill in Dlg%hWnd. In this way, the Dlg structure is "almost" valid, but DialogProc is yours, not the one within DFLOGM. Now, take a look at source of DFLOGM.f90: when you call DlgSetChar, it calls DlgFlush at the end to synchronize dialog appearance with contents of Dlg structure. It calls Data2Dialog, which within CASE(ctrl_radiobutton) ultimately calls:
dummyi = DlgSendMessage( hwndControl, BM_SETCHECK, &
log2int( dlg % list(index) % logvalue(2) ), 0 )
The variable in question is by default initialized to .TRUE. in DlgInit for the first radio button. So, it "magically works".
Do not fiddle with DFLOGM once you wrote your own DialogProc and invoked it with DialogBox(Indirect) API. Instead, initialize your controls using native APIs -- mostly Send(DlgItem)Message. So, the "real" solution is to
SendDlgItemMessage(hDlg,IDC_FIRSTRADIO,BM_SETCHECK,BST_CHECKED,0)
on WM_INITDIALOG. There's also CheckRadioButton API (which is actually just a wrapper around BM_SETCHECK).
Most of your DialogProc will contain calls to SendDlgItemMessage, which is (more or less) what DlgSet/DlgGet do. Although the number of message symbolic names is big, they're systematized rather consistently: for example, BM_ are button messages, EM_ edit box messages, CB_ combobox etc. And you can always refer to source of DFLOGM.f90 (particularly Data2Dialog and Dialog2Data) to find out how it's implemented there -- just don't USE it. You might get away with it, as in this case, but IMO you're asking for trouble.
Jugoslav
michael_green
Thankyou, Jugoslav, I am beginning to see the light now.
Mike
