do loop
keremusu1
Hello!
I would like to create a loop as follows:
The only variable in my loop is the time t, which goes from 0 to 120 by an increment of 1 (t=0,120,1). With this variable, I would like to calculate:
r2=(q8*t)-(g*t*log(t))+(q9*t)-(q10/(exp(t/T2)))
All other variables (q8,g,q9,q10,T2) are known.
What should my code be like?
log(0) is going to give you a problem...
keremusu1
It can also be (t=1,120,1)
Les_Neilson
Valued Contributor II
integer :: t
do t=1,121
r2 = (q8*t) - (g*t*log(t)) + (q9*t) - (q10/(exp(t/t2)))
enddo
Les
Les_Neilson
Oops sorry
do t=1,120
