enomem problem
pjeandel
Hi all,
I am trying to run a code that has in the past run on NEC vector machines, on an intel xeon x5550 blade (sgi). The code is written in F90, and compiles with no warning messages. It requires a relatively large amount of memory, around 6 GB, and has large, statically declared, arrays (typically 512x119x460). I am running into strange behaviour regarding memory, and openmp (compiler version 11.1).
- compiled with "ifort -O0 -r8 -mcmodel=medium -o no_omp filename.f90 " and run with ulimit -s unlimited, the execution fails with the following message: execve("./test_omp", ["test_omp"], [/* 89 vars */]) = -1 ENOMEM (Cannot allocate memory)
+++ killed by SIGKILL +++
- compiled with "ifort -O0 -r8 -openmp -mcmodel=medium -o no_omp filename.f90 " and run on any number of threads between 1 and 8, I get no problems.
Can anyone point me in the right direction for solving this problem?
Many thanks
Stephen_D_Intel
The -openmp compiler option invokes the -automatic option which will move more of your program's variables to the run-time stack. You could try building the no_omp version of your program with the -automatic option to see if it has any effect.
Steve D.
Intel Developer Support
TimP
Specifically, setting -openmp or -auto, or declaring the function/subroutine recursive, places locally declared arrays on the stack, and makes them go out of scope when the subroutine exits, unless they are declared with SAVE.
