equivalent of LOC
abhimodak
This question is "out of scope" for Intel Fortran. But I am just taking a chance....
Since IVF still doesn't support procedure pointers and type bound procedures, I have been using the Cray style pointers, as suggested by Steve,to fake this. I used intrinsic function LOC to get the address of an external procedure.
However, the other platform that we need to support is IBM and unfortunately LOC intrinsic on that platform is not valid for external procedures. Does anyody know a "common set" that can be used on these two platforms to mimick procedure pointers and type bound procedures?
Abhi
Does the IBM compiler support passing a variable by value? Which IBM compiler are you using? xlf is ahead of Intel Fortran in F2003 support.
jimdempseyatthecove
Abhi,
Considerusing the attribute external. From my QuickThread tool see how the test are run by way of address of function.
Look downnear bottom of code for call to RunTest(...) then look at interface in module (sorry about tabbing as paste code removes that)
This would require some adaptaton to call proceedures (as seperate process in seperate address space) but the sample code should a good basis for how you would do this.
Jim Dempsey
! SimpleArray.f90
! FUNCTIONS:
! SimpleArray - Entry point of console application.
! PROGRAM: SimpleArray
! PURPOSE: Entry point for the console application.
module
SimpleArray_mod
use PerformanceCounter
use QuickThreadInterfaces
! Declare application Performance Counter
type(T_PERFORMANCECOUNTER) :: ThePerformanceCounter
integer :: ArraySize
integer :: ArraySizeBegin = 1000
integer :: ArraySizeLimit = 1000000
! TestRunTimeDesired
! Number of seconds of run time desired for single threaded test
real(8) :: TestRunTimeDesired = 10.
real(8) :: SingleThreadedRunTime
! NumberOfIterations
! Calculated at initialization to produce single threaded run time
! of TestRunTimeDesired seconds
integer :: NumberOfIterations
! isTemporal = .true. if array processing has temporal characteristics
! isTemporal = .false. if array processing has no temporal characteristics
logical :: isTemporal
real(8), allocatable :: A(:) ! Allocated to ArraySize
real(8), allocatable :: B(:) ! Allocated to ArraySize
real(8), allocatable :: C(:) ! Allocated to ArraySize
! Declare the interface to your copy of QuickThreadQueueMainTemplate
interface
integer(DWORD) function QueueMain(MainCode)
use kernel32
implicit none
logical, external :: MainCode
end function QueueMain
end interface
interface
subroutine RunTest(Test, isQuickThread, Name)
external :: Test
logical :: isQuickThread
character*(*) :: Name
end subroutine RunTest
end interface
! Define interface to DoSimpleArraySlice
interface
subroutine DoSimpleArraySlice(iFrom, iTo)
!DEC$ ATTRIBUTES VALUE :: iFrom
integer :: iFrom
!DEC$ ATTRIBUTES VALUE :: iTo
integer :: iTo
end subroutine DoSimpleArraySlice
end interface
end module
SimpleArray_mod
program
SimpleArray
use SimpleArray_mod
implicit none
! Variables
integer :: i, j
real(8) :: SingleThreadRunTimeInSeconds
real(8) :: OpenMPRunTimeInSeconds
real(8) :: QuickThreadRunTimeInSeconds
real(8) :: PerformanceGain
! Test subroutines
exter nal :: SingleThreadTest
external :: OpenMPTest
external :: QuickThreadTest
! Body of SimpleArray
write(*,*) 'SimpleArray'
write(*,*) 'Specified runtime', TestRunTimeDesired
write(*,*) ''
ArraySize = 0
do while(ArraySize .lt. ArraySizeLimit)
if(ArraySize .eq. 0) then
ArraySize = ArraySizeBegin
else
ArraySize =
min(ArraySize*2, ArraySizeLimit)
endif
write(*,*) 'ArraySize = ', ArraySize
! allocate the arrays
allocate(A(ArraySize))
allocate(B(ArraySize))
allocate(C(ArraySize))
! initialize arrays B and C to random numbers
call RANDOM_NUMBER(B)
call RANDOM_NUMBER(C)
! Calibrate iteration count to produce a single threaded
! run time of TestRunTimeDesired seconds
! Perform calibration after allocation and initialization of arrays
call CalibrateRuntime
SingleThreadedRunTime = 0.
call RunTest(SingleThreadTest, .false., "Single Threaded")
call RunTest(OpenMPTest, .false., "OpenMP")
isTemporal = .true.
write(*,*) "Temporal", isTemporal
call RunTest(QuickThreadTest, .true., "QuickThread")
! return memory
deallocate(A)
deallocate(B)
deallocate(C)
end do
!DEC$ IF DEFINED(_DEBUG)
! If debugging, pause to permit reading of console window before exit
write(*,*) ""
pause
!DEC$ ENDIF
end
program SimpleArray
subroutine
CalibrateRuntime
use SimpleArray_mod
implicit none
! Initialize the Performance Counter code
call PerformanceCounterInit
ThePerformanceCounter.RunTimeInSeconds = 0.
NumberOfIterations = 1
do while(ThePerformanceCounter.RunTimeInSeconds .lt. 0.5)
! First order Estimation accuracy to ~1%
! Make a run of NumberOfIterations
call PerformanceCounterStart(ThePerformanceCounter)
call SingleThreadTest
call PerformanceCounterEnd(ThePerformanceCounter)
! Compute the number of iterations to run for 1 second
int(dble(NumberOfIterations) * 1.0_8 / ThePerformanceCounter.RunTimeInSeconds)
end do
! Compute the number of iterations to run for TestRunTimeDesired
int(dble(NumberOfIterations) * TestRunTimeDesired / ThePerformanceCounter.RunTimeInSeconds)
end subroutine
CalibrateRuntime
subroutine
use SimpleArray_mod
implicit none
external :: Test
character *(*) :: Name
integer :: iTrash
write(*,100) Name
100
format(A15,' ',$)
if(isQuickThread) then
! ignore error
iTrash = QueueMain(Test)
else
call Test
endif
if(SingleThreadedRunTime .eq. 0.) SingleThreadedRunTime = ThePerformanceCounter.RunTimeInSeconds
write(*,200) ThePerformanceCounter.RunTimeInSeconds, (SingleThreadedRunTime / ThePerformanceCounter.RunTimeInSeconds) * 100.0_8
200
format(F15.12, F15.9,'%')
end subroutine
RunTest
subroutine
SingleThreadTest
use SimpleArray_mod
implicit none
! Local Variables
integer :: i, j
! Code
do i=1, NumberOfIterations
do j=1, size(A)
A(j) = B(j) + C(j)
end do
end do
end subroutine
SingleThreadTest
subroutine
OpenMPTest
use SimpleArray_mod
implicit none
! Local Variables
integer :: i, j
! Code
!$OMP PARALLEL DO
do j=1, size(A)
A(j) = B(j) + C(j)
end do
!$OMP END PARALLEL DO
end do
end subroutine
OpenMPTest
subroutine
QuickThreadTest
use SimpleArray_mod
implicit none
! Local Variables
! Stack local control structure
type(T_QuickThreadControlStructure) :: qtControl
integer :: i
! code
! Slice the array processing by number of worker threads
! across range of 1 to size of array A (B, and C)
call QuickThreadQueueDo(qtControl, DoSimpleArraySlice, 1, size(A))
if(isTemporal) call QuickThreadWaitTillDone(qtControl)
end do
if(.not. isTemporal) call QuickThreadWaitTillDone(qtControl)
end subroutine
QuickThreadTest
! DoSimpleArraySlice
! Perform work on slice of arrays A, B, and C
subroutine
use SimpleArray_mod
implicit none
integer :: iFrom
integer :: iTo
! Local Variables
integer :: j
do j=iFrom, iTo
A(j) = B(j) + C(j)
end do
end subroutine
DoSimpleArraySlice
abhimodak
Hi Steve and Jim
Thanks for you answer.
Attached code snippet shows exactly what I am trying to do.
I (sadly) know that XLF is way ahead of Intel Fortran but I must usethe same code on both platforms.
Function %VAL and %REF are available on IBM. LOC is also available but unlike Intel, it cannot be used for a procedure. IBM cannot use cray pointers with procedure name either.
I will try to understand Jim's code.
Sincerely
Abhi
