29275 Discussions
error #10308 and test version of IVF11 ?
Christoph_Waechter
Before activation/registration of the IVF 11 Pro permanent license I made some trials with the 30 days test-license on my two quad-core opterons machine running x64. For IA32 things went fine, but any attempt to compile/build for x64 did result in error #10308:
--> Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based license could not be supported
Might this be due to some restrictions of the test-license ? Or can this be more severe, and, if so, what might help ?
Thanks for any comment / hint / advice.
Christoph
I haven't seen that one before, but my guess is that it has to do with the "no serial number required" 30-day trial, where the licensing software on its own gives you a 30-day trial. I'll ask our licensing folks if they have heard of this.
You should not encounter this problem if you reinstall with a serial number. If you want to test this, go here to apply for an Evaluation license. You'll be emailed a serial number. Uninstall the compiler from the x64 system and reinstall using the serial number.
