29650 Discussions
error #5102: Cannot open include file '(filename)'
Robert_Massey
I'm using Intel Visual fortran Composer XE for Windows - Package ID w_fcompxe_2011.10.325 under Visual Studio 2010 Professional Version 10.0.30319.1 RTMRel.
I'm simply trying to compile and build a set of existing Fortran subroutines. I add the existing .f source files to theSource Files directory of the projectwithin Solution Explorer. These routines have many includes. Regardless of where I add the .inc files (whether to 'Source Files', 'Resource Files', or 'Header Files'), all of the INCLUDE statements return "error #5102: Cannot open include file '(file name)'."
Can anyone kindly shed light on what I might be doing wrong in the environment installation and configuration and/or fortran project build?
DavidWhite
Valued Contributor II
From MSVS Under Tools / Options / Intel Visual Fortran / Compilers are settings for the include folders. Has thefolder for your include files been added there?
David
DavidWhite
David
Robert_Massey
Thank you David, I was able to set the correct paths based on your comment. -Robert
DavidWhite
Robert,
Be aware that not of the settings for Include paths, etc, are saved when updating IVF. So if you make any changes there, copy all the folder details to a text file, so that you can restore them after an update.
It is a real pain, hopefully one day the Intel team can fixthe installer so it does not break this every time.
David
IanH
If the include paths are specific to the project and not specific to a particular machine then the OP should consider placing them in the project settings (right click on the project, select Properties, then under Fortran > General set Additional Include Directories). Project settings survive Visual Studio upgrades and also travel with the project if it is moved to a different machine.
Selo_Imrohoroglu
I am trying to run Intel Composer XE 2013 SP1 (Fortran) (under MS Visual Studio 2010 and Parallels on Macbook Pro Mavericks).
I followed the directions in https://software.intel.com/en-us/articles/installing-and-using-the-imsl-libraries/ but still get the error #5102 cannot open include library .. message.
Any help is appreciated.
Suresh_A_
I have the similar problem. I am trying the list the INCLUDE file source in my source as follows:
INCLUDE 'GEPARM.FOR/LIST" to include the common block list in the output list but it gives the following error.
Error    1     error #5102: Cannot open include file 'GEPARM.FOR/LIST'    G:\oms-Development\Version-VB6\Interfaces\omsLPIntf\Source\Fortran\omsLPIntfDll\GEINTF.FOR    56
But if remove /LIST option, it compiles OK but does not list the source for include file.
What am I doing wrong here ?
/LIST in an INCLUDE file specification is a VMS feature. To get it to be supported in Intel Fortran, enable the VMS option under Fortran > Compatibility - but be aware of the other things that changes. Of course, you won't see anything unless you also generate a source listing file.
Suresh_A_
Thanks Steve. It worked
