error #5415
Tripp_L_
I'm very frustrated by this error. Not only is it a feature for Fortran 2003 and it is 2014, but it keeps me from being able to file read using namelist for a derived type that contains any allocatable elements or types containing allocatable elements even if I'm not assigning anything to those fields in the namelist read.
Is there a workaround/fix other than creating a second type without the allocatable elements and transferring them post-read?
jimdempseyatthecove
It sounds like the OP wants a magic solution where he can perform:
OPEN(someFileOfUnknownLayout)
READ(saidFile) IntoGenericObject
And do so without writing import code (User defined type I/O).
Once ingested, I would imagine the OP wants magic operators without writing the operator code.
I might suggest that the OP look at using a library such as HDF5 (http://www.hdfgroup.org/HDF5/), or any or the XML parser libraries. These may still require user defined type I/O if he does not want to use the library's get and put routines (performance).
A simpler method would be to consider an INI file processor (http://www.fortranlib.com/iniFile.for):
C PARSER - parse an ini file
C     V1.0 6 AUG 03
C     Written by Douglas S. Elder [email protected]
C** common block that will contain the iniFile
      BLOCK DATA iniFile
      LOGICAL initialized
      INTEGER CNT
      CHARACTER LINES(100)*256
      CHARACTER iniFilename*256
      COMMON /Options/ CNT, LINES, initialized, iniFilename
      DATA initialized, CNT, iniFilename / .FALSE., 0, 'Options.ini' /
      END
C** allow you to use a different iniFile or to switch to another
      SUBROUTINE setIniFilename(value)
      CHARACTER value*(*)
      LOGICAL initialized
      INTEGER CNT
      if (initialized .EQV. .TRUE.) then
        if (value .NE. iniFilename) then
        iniFilename = value
C****** switching to a different ini file
                call loadOptions
        end if
      else
C****** overriding the default ini file
        iniFilename = value
      end if
      END
C***** search for the Section and keyword, if found return its value
C***** otherwise return the default
      SUBROUTINE getValue(section, kwd, value, default)
      IMPLICIT NONE
      CHARACTER section*(*)
      CHARACTER kwd*(*)
      CHARACTER value*(*)
      CHARACTER default*(*)
      INTEGER I
C**      WRITE(*,*) 'getValue', section, kwd, value, default
      value = ''
      call getValueX(section, kwd, value)
C**      WRITE(*,*) 'Got value ', value
      if (value .EQ. '') then
  value = default
      end if
      END
C**** read in the iniFile into the common Options block
      SUBROUTINE loadOptions
      IMPLICIT NONE
      INTEGER CNT
      LOGICAL initialized
      CHARACTER LINE*256
C**      WRITE(*,*) 'loadOptions'
      CNT = 0
      OPEN(UNIT=33, FILE=iniFilename)
1     READ(33,'(A)', END=10) LINE
      CNT = CNT + 1
      if (CNT .GT. 100) then
C**         WRITE(0,*) 'Options.ini file > 100 lines.'
  STOP 16
      else
       LINES(CNT) = LINE
      end if
      GOTO 1
10    CONTINUE
C**      WRITE(*,*) 'CNT = ',CNT
      CLOSE (UNIT=33)
      initialized = .TRUE.
      END
C*** try to find the Section and keyword, if found return its value
C*** otherwise return an empty string
      SUBROUTINE getValueX(section, kwd, value)
      IMPLICIT NONE
      CHARACTER kwd*(*)
      CHARACTER value*(*)
      INTEGER I, J, STARTVAL
      INTEGER CNT
      LOGICAL initialized
      INTEGER MAXLINE
      PARAMETER (MAXLINE = 256)
      CHARACTER LINE*256
      LOGICAL foundSection, foundKwd
      if (initialized .EQV. .FALSE.) then
            call loadOptions
      end if
      foundSection = .FALSE.
      foundKwd = .FALSE.
      value = ''
C**      WRITE(*,*) 'Looking for ',section
      DO I=1, CNT
       if (LINES(I)(1:1) .EQ. '[') then
  DO J=2, MAXLINE
    if (LINES(I)(J:J) .EQ. ']') then
   if (section .EQ. LINES(I)(2:J-1)) then
    foundSection = .TRUE.
C**    Write(*,*) 'foundSection=', foundSection
    GOTO 15
   end if
    end if
  ENDDO
 else
  if (foundSection .EQV. .TRUE.) then
                        STARTVAL = 0
C**   WRITE(*,*) 'Looking for keyword ', kwd
   DO J=1, MAXLINE
    if (LINES(I)(J:J) .EQ. '=') then
     if (kwd .EQ. LINES(I)(1:J-1)) then
      STARTVAL = J+1
      foundKwd = .TRUE.
C**      Write(*,*) 'found keyword ', kwd
      GOTO 13
     end if
    end if
   END DO
13   CONTINUE
   if (foundKwd .EQV. .TRUE.) then
    DO J=MAXLINE, STARTVAL, -1
C**     Write(*,*) 'Looking for value at ', STARTVAL, J
     if (LINES(I)(J:J) .NE. '') then
      value = LINES(I)(STARTVAL:J)
C**      Write(*,*) 'Got value at line ', I, ' pos ', STARTVAL, J
      GOTO 20
     end if
    END DO
   end if
  end if
 end if
15 CONTINUE
      ENDDO
20    CONTINUE
      END
Jim Dempsey
