29348 Discussions
error #5508: "This is in conflict with a previous declaration."
WSinc
When I installed it, I got an error I have never seen before in this project.
I didn't change ANY code.
It gives me an error #5508:
This was the only declaration.
A clean and rebuild does NOT work.
Now I can't compile my project at all.
Ron_Green
bug report is DPD200120387
I'll keep everyone posted on progress.
ron
Robinson__Donald
I have an MS Visual studio 2005 solution with one Fortran and one C project. I can clean and build Debug and Release versions with Version 11.0.061, with these statements (/flags shown in UI) in the vfproj file:
Interfaces="true" (/gen-interfaces)
WarnInterfaces="true" (/warn:interfaces)
When I perform a clean and build with Version 11.0.074 with the same 2 interface options, I obtain the following error:
2>F:Visual Studio 2005FVSECbasesrcstats.for(1): error #5508: Declaration of routine 'STATS' conflicts with a previous declaration
The error can occur with different routines (not just 'STATS').
Ron_Green
Yes, the same bug. The name of the subroutine (symbol) can be anything.
We have 2 simple reproducers in our bug report and have raised this to the highest criticality.
ron
Ron_Green
All,
I've taken the liberty to change the thread title to make it easier for others to discover (I think we'll see more users with this issue).
thanks
ron
davenport-nswcpc
I applied this fix and the error has gone away......... I suppose until something else goes wrong. Thank you brian for posting that.
Really, if this forum wasn't soooooooooo slooooooow I'd come here more often and not just when something bad happens.
ardavenport
Quoting - bmchenry
turn off the 'Generate Interface Blocks' option of
Project menu->"your project" Properties->Fortran->Diagnostic->Generate Interface Blocks
i was experiencing similar errors and eliminated them by this simple change.
brian
onkelhotte
New Contributor II
When will Intel releasean update on 11.0.072? My license expires this month and it would be unfortunate to miss the fix on this issue...
Markus
The next update will be 11.1, out later this month, and it will include the fix for this. If your support expires in June, you'll be able to install the initial 11.1.
Ron_Green
Quoting - donrobinson
Just to close this out - this bug was fixed in the 11.1 compilers and in the most current 11.0 compilers (download from https://registrationcenter.intel.com
ron
Stuart_M_
Quoting - onkelhotte
Markus
Hi Steve
I have hit this bug but my license expired in April. Do I have to buy a new license in order to download the fix, even though the version I have downloaded came with the bug? Seems to be, but all seems to be a bit unfair, so just wanted to check with someone a little more in-the-know.
Thanks man
Yes, or you could back down to an earlier 11.0 version that didn't have the bug (I think it was only in that one version.)
onkelhotte
New Contributor II
Quoting - stubaan
Hi Steve
Thanks man
Steve, had Intel thought about releasing the compiler and the VS Integration seperatly? For example, the compilerneeds a valid license (just like now) and the integration comes for free?
I know, that this bug is compiler related, but there were (and maybe are and will be)Integration bugsand buying a new license only for editing reasons when you dont need the new compiler features is not fair (just my $0.02).
Markus
No, we haven't considered that and probably won't. Our packaging and testing is complex enough as it is.
