29523 Discussions
error #6341 - ifx can't compile line like: if(aFunction)
cean
New Contributor II
Here is a demo.
! if_aFunc.f90
! Compile with:
! ifx if_aFunc.f90
! Compiling Errors:
!Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2025.1.0 Build 20250317
!Copyright (C) 1985-2025 Intel Corporation. All rights reserved.
!if_afunc.f90(27): error #6385: The highest data type rank permitted is INTEGER(KIND=8).   [AFUNC]
!      if (aFunc(sText1)) print *,'false'
!if_afunc.f90(27): error #6341: A logical data type is required in this context.   [AFUNC]
!compilation aborted for if_afunc.f90 (code 1)
!source
      logical      :: iRet
      iRet = aFunc(sText1)
      if (iRet) print *,'Work'
      !Can't compile next line
      if (aFunc(sText1)) print *,'Not Work.'
      end
RECURSIVE LOGICAL FUNCTION aFunc()
      aFunc=.TRUE.
END FUNCTION aFunc
Steve_Lionel
The compiler is correct, because aFunc is implicitly REAL and not allowed as the IF expression. It's possibly also a mismatch in your real application. Try this instead:
      logical      :: iRet, aFunc
      end
cean
New Contributor II
why this definition doesn't work: RECURSIVE LOGICAL FUNCTION aFunc()
How to define a function to return a  LOGICAL value?
I am trying to compile Xeffort. It has a lost of this kind of call.
witwald
New Contributor II
Here is a working example of your original code. It compiles and runs using the Intel ifx compiler (under Windows). It is necessary to ensure that the data types are explicitly declared. Using 'implicit none' will help you to ensure that this is the case.
program prog_if_aFunc
implicit none
logical           :: aFunc, iRet
character(len=20) :: sText1
if (iRet) print *,'Works - iRet'
if (aFunc(sText1)) print *,'Works - aFunc'
end
RECURSIVE LOGICAL FUNCTION aFunc(sText)
  implicit none
  character(len=*), intent(in) :: sText
  aFunc = .TRUE.
END FUNCTION aFunc
 Below is the output:
 Works - iRet
 Works - aFunc
cean
New Contributor II
No, you have the redeclare in the main.
logical :: aFunc
I don't want to add this.
witwald
New Contributor II
The compiler is not clairvoyant when it comes to using functions in a program. In the C programming language, this issue is gotten around by the use of header files. That way the compiler knows how to deal with a function when it encounters it. Of course, most Fortran compilers handle intrinsic functions, which are part of the language standard and are thus well defined, in the manner you are thinking of.
Steve_Lionel
The main program doesn't know the declaration of aFunc as it is a separate subprogram. Just having it in the same source file is not sufficient. Given this, you must declare it in the main program or from whichever program unit you call it from. You can avoid this by putting aFunc in a module and USEing the module in the main program,. or by making aFunc an internal subprogram of the main, after a CONTAINS.
For further reading, see my 2012 post Doctor Fortran Gets Explicit - Again! - Doctor Fortran
cean
New Contributor II
Thanks all.
I got this question when trying to compile Xeffort.
Look at the code, it is in a module. Like the STRCMP function in xftstrings.f90
