29341 Discussions
error #6401: The attributes of this name conflict with those made accessible by a USE statement. [X]
sarma_amras
Can you please help me with this err
I am getting this err when I try accessing a variable declared in MODULE ZF5 with the EQUIVALENCE statement.
Kameswara Sarma
TimP
Quoting - sarma_amras
According to my reading of Adams, Brainerd et al, the module array technically must be declared with SEQUENCE before it can be mentioned in EQUIVALENCE. If this is the problem, I suppose the error message ought to be more informative.
We have had problems in the past with ifort being unwilling to diagnose extensions beyond Fortran standard which aren't accepted by other compilers.
I think the real problem here is that once you USE a module, you cannot change attributes of any of the symbols that came from the module, with minor exceptions. Here, you have a variable X in the module, and then EQUIVALENCE it to A in the main program. This is not allowed. You'll have to move A into the module as well if you want to do this.
You're not using derived types, so SEQUENCE is not applicable.
TimP
Unlike the Adams, Brainerd textbook, the standard is more explicit about the restriction against non-sequence types in EQUIVALENCE applying to derived types. I don't find the explicit statement about the requirement Steve mentions, although I'm not surprised by it.
11.2.1, p252:
30 The local identifier of an entity made accessible by a USE statement shall not appear in any other
31 nonexecutable statement that would cause any attribute (5.1.2) of the entity to be specified in the
32 scoping unit that contains the USE statement, except that it may appear in a PUBLIC or PRIVATE
33 statement in the scoping unit of a module and it may be given the ASYNCHRONOUS or VOLATILE
34 attribute.
The text I cite above doesn't cover EQUIVALENCE, since that is not an attribute. However, there is this:
C585 (R556) The name of an equivalence-object shall not be a name made accessible by use association.
sarma_amras
Steve...I tried with both X(50) & A(50) included in the module statement as suggested.
But still the error is persisting with both the variables used.
I guess we cannot use equivalence keyword with the variables used in module statement.
Please suggest.
Kameswara Sarma
sarma_amras
Quoting - tim18
Tim ... can you please elaborate on the use of what you have suggested? Sarma
Please show us your modified source. If you still have an EQUIVALENCE in the main program, that won't work.
Tim's comments on SEQUENCE don't apply to your program.
sarma_amras
I still have the Equivalence in the main program. But the variable used with Equivalence is also present in MODULE.
Can I use the Equivalence now. I still face the error. Please suggest
You cannot have the EQUIVALENCE in the main program if any of the variables listed are module variables. If you are still having problems, please show us the new code.
