29487 Discussions
error #6405: The same named entity from different modules and/or program units cannot be referenced. [ISK]
sarma_amras
I am using a module defined with the variables like ISK.
I am trying to use the same in another subroutine and face this error #6405.
I am populating values into the module containing ISK using Namelist.
I didn't declare this varible anywhere else except in the module created and passing it as an argument from the main program and trying to do a comparison in the subroutine.
Please suggest.
Kameswara Sarma
TimP
If your question is about hiding module variables selectively, the choices of PRIVATE or ONLY are available.
Can you construct a small example that shows the problem? I can't quite figure it out from your description.
