error #6413
Brooks_Van_Horn
In coding for a gui application (not qwin) I've run into a slight problem with compiling a subroutine.
1>------ Build started: Project: Pearson, Configuration: Debug x64 ------
1>Compiling with Intel(R) Visual Fortran Compiler 16.0 [Intel(R) 64]...
1>DoGrids.f90
1>C:\Users\Brooks\Desktop\Projects\Pearson\Pearson\DoGrids.f90(26): error #6413: This global name is invalid in this context.   [SETWINDOWORG]
1>C:\Users\Brooks\Desktop\Projects\Pearson\Pearson\DoGrids.f90(37): error #6413: This global name is invalid in this context.   [SETWINDOWEX]
1>C:\Users\Brooks\Desktop\Projects\Pearson\Pearson\DoGrids.f90(48): error #6413: This global name is invalid in this context.   [SETVIEWPORTEX]
1>compilation aborted for C:\Users\Brooks\Desktop\Projects\Pearson\Pearson\DoGrids.f90 (code 1)
These three routines are needed. There is no use that I've found so I created 3 interfaces that I designed using msdn as a guide. They are:
interface
   function SetWindowOrg(hdc, x, y, pt)
use ifwinty
   integer(BOOL),intent(out):: SetWindowOrg
   !DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'SetWindowOrg' :: SetWindowOrg
   integer(HANDLE),Intent(in):: hdc
   integer(4),Intent(in):: x, y
   !DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: pt
   type(T_POINT),Intent(out):: pt
   end function setWindowOrg
end interface
interface
   function SetWindowEx(hdc, x, y, pt)
use ifwinty
   integer(BOOL),intent(out):: SetWindowEx
   !DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'SetWindowEx' :: SetWindowEx
   end function setWindowEx
end interface
interface
   function SetViewportEx(hdc, x, y, pt)
use ifwinty
   integer(BOOL),intent(out):: SetViewportEx
   !DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'SetViewportEx' :: SetViewportEx
   end function SetViewportEx
end interface
So I don't understand the error messages. I've tried compiling without the interfaces and still problems!
Sincerely,
Brooks Van Horn
You can't use INTENT on the function result. Just declare the function names with the type.
Brooks_Van_Horn
Steve,
OK that gets it past the compile stage but I now get 3 external references on those functions that are unknown.
Brooks
1>ipo: error #11023: Not all components required for linking are present on command line
1>ipo_6969278obj3.obj : error LNK2019: unresolved external symbol SetWindowEx referenced in function DOGRIDS
1>ipo_6969278obj3.obj : error LNK2019: unresolved external symbol SetViewportEx referenced in function DOGRIDS
1>ipo_6969278obj3.obj : error LNK2019: unresolved external symbol SetWindowOrg referenced in function DOGRIDS
1>x64\Debug\Pearson.exe : fatal error LNK1120: 3 unresolved externals
1>
Brooks_Van_Horn
According to MSDN these should be in gdi32.lib. So why would MSVS 2013 not pick it up?
Brooks
IanH
Win32 does not have the SetWindowOrg API - that was for Win16 only.  The API you want is SetWindowOrgEx.
Similarly you may have been looking for SetViewportOrgEx for one of the other API's.
ifort provides interfaces to those API's in the GDI32 module.
