29487 Discussions
error #6457 This derived type name has not been declared
Clarence_N_
Hi All,
I recently met a problem with error message "error #6457: This derived type name has not been declared.   [DRTYP]" in my code.
module derivetypetest
    implicit none
!DEC$ IF DEFINED (abc)
         type StringPointer
            character (len=1), pointer :: sp
         end type StringPointer
         type drtyp
            integer dim, size
            integer (kind=IntKind), pointer :: array(:,:)
         end type drtyp
!DEC$ ELSEIF DEFINED (def)
         type drtyp
            integer size
            integer (kind=IntKind), pointer :: array(:)
         end type drtyp
         character (len=1), private, allocatable :: whatever(:)
!DEC$ ENDIF
         private :: drtyp
         type(drtyp), private:: drtyparr(5)
end module derivetypetest
A workarround I used is that I put
         private :: drtyp
in !DEC$ IF and !DEC$ ELSEIF.
May I ask if there's other option to keep the codes in the original form?
JVanB
Valued Contributor II
If neither abc nor def is defined, you should expect that error message. Maybe you could put a !DEC$ ELSE clause in there that defines TYPE(drtyp) in that case.
Clarence_N_
Thanks! This works.
