29648 Discussions
error #7001: Error in creating the compiled module file.
Behnam_M_
Hi All
I am trying to compile a fortran file with ifortran on a redhat linux machine.
I get the following error when I try to compile it. I have attached the file to this post.
I already have files "NWTC_Library.mod" , "precision.mod" and "Aerodyn.mod" in the same directory.
Any help would be appreciated.
Thank you
bash-4.1$ ifort  -O2 -fpp -real-size 64 -traceback -I Obj_lin64 -module Obj_lin64 -c FAST_Mods.f90 -o FAST_Mods.o
FAST_Mods.f90(2): error #7001: Error in creating the compiled module file.   [ADAMSINPUT]
MODULE ADAMSInput
FAST_Mods.f90(46): error #7001: Error in creating the compiled module file.   [AEROELEM]
MODULE AeroElem
FAST_Mods.f90(66): error #7001: Error in creating the compiled module file.   [BLADES]
MODULE Blades
FAST_Mods.f90(143): error #7001: Error in creating the compiled module file.   [COORDSYS]
MODULE CoordSys
FAST_Mods.f90(213): error #7001: Error in creating the compiled module file.   [CONSTANTS]
MODULE Constants
FAST_Mods.f90(227): error #7001: Error in creating the compiled module file.   [DOFS]
MODULE DOFs
FAST_Mods.f90(313): error #7001: Error in creating the compiled module file.   [DRIVETRAIN]
MODULE DriveTrain
FAST_Mods.f90(372): error #7001: Error in creating the compiled module file.   [ENVCOND]
MODULE EnvCond
FAST_Mods.f90(410): error #7001: Error in creating the compiled module file.   [FEATURES]
MODULE Features
FAST_Mods.f90(442): error #7001: Error in creating the compiled module file.   [GENERAL]
MODULE General
FAST_Mods.f90(486): error #7001: Error in creating the compiled module file.   [INITCOND]
MODULE InitCond
FAST_Mods.f90(519): error #7001: Error in creating the compiled module file.   [LINEAR]
MODULE Linear
FAST_Mods.f90(554): error #7001: Error in creating the compiled module file.   [MASSINERT]
MODULE MassInert
FAST_Mods.f90(598): error #7001: Error in creating the compiled module file.   [MODES]
MODULE Modes
FAST_Mods.f90(676): error #7001: Error in creating the compiled module file.   [NACELLEYAW]
MODULE NacelleYaw
FAST_Mods.f90(712): error #6401: The attributes of this name conflict with those made accessible by a USE statement.   [OUTPARMTYPE]
   END TYPE OutParmType
FAST_Mods.f90(712): error #6148: The name on this END TYPE statement is different from the name on the corresponding derived type statement   [OUTPARMTYPE]
FAST_Mods.f90(726): error #6401: The attributes of this name conflict with those made accessible by a USE statement.   [TIME]
   INTEGER, PARAMETER             :: Time      =    0
FAST_Mods.f90(1904): error #6401: The attributes of this name conflict with those made accessible by a USE statement.   [FILEFMTID_WITHTIME]
INTEGER(B2Ki), PARAMETER     :: FileFmtID_WithTime    = 1                       ! ID for OutputFileFmtID to specify that the time channel should be included in the output file (use if the output can occur at variable times)
FAST_Mods.f90(1905): error #6401: The attributes of this name conflict with those made accessible by a USE statement.   [FILEFMTID_WITHOUTTIME]
INTEGER(B2Ki), PARAMETER     :: FileFmtID_WithoutTime = 2                       ! ID for OutputFileFmtID to specify that the time channel does not need to be included in the output file (used only with constant time-step output)
FAST_Mods.f90(1917): error #6401: The attributes of this name conflict with those made accessible by a USE statement.   [OUTPARMTYPE]
TYPE(OutParmType),ALLOCATABLE:: OutParam (:)                                    ! Names and units of all output parameters.
FAST_Mods.f90(2089): error #7001: Error in creating the compiled module file.   [PLATFORM]
MODULE Platform
FAST_Mods.f90(2133): error #7001: Error in creating the compiled module file.   [ROTORFURLING]
MODULE RotorFurling
FAST_Mods.f90(2159): error #7001: Error in creating the compiled module file.   [RTHNDSID]
MODULE RtHndSid
FAST_Mods.f90(2283): error #7001: Error in creating the compiled module file.   [SIMCONT]
MODULE SimCont
FAST_Mods.f90(2305): error #7001: Error in creating the compiled module file.   [TAILAERO]
MODULE TailAero
FAST_Mods.f90(2333): error #7001: Error in creating the compiled module file.   [TAILFURLING]
MODULE TailFurling
FAST_Mods.f90(2359): error #7001: Error in creating the compiled module file.   [TEETERVARS]
MODULE TeeterVars
FAST_Mods.f90(2381): error #7001: Error in creating the compiled module file.   [TIPBRAKES]
MODULE TipBrakes
FAST_Mods.f90(2398): error #7001: Error in creating the compiled module file.   [TOWER]
MODULE Tower
/tmp/ifortRhrSha.i90(2471): catastrophic error: Too many errors, exiting
compilation aborted for FAST_Mods.f90 (code 1)
bash-4.1$
The main issue I see is that the compiler thinks it can't write files into the folder Obj_lin64 - does that folder exist and do you have write permission for it?
Behnam_M_
Hi Steve
Yes. I have already compiled filed and written to the folder Obj_lin64.
Kevin_D_Intel
Any possibility file quotas might be at play where Obj_lin64 resides?
Behnam_M_
Hi Kevin
I am not sure about what you are saying (I am an amateur in working with ifortran). How can I check that?
Kevin_D_Intel
I'm referring to disk usage quotas imposed by the OS. Those are displayed by the quota command or for more info use man quota.
If you have not already, check whether there is available space (use the df command).
Behnam_M_
I guess there isn't any problem with that.
cyfilesnfs.iastate.edu:/root_vdm_4/cyfiles/22/16/behmogh 2132123648 788206272 1343917376  37% /home/behmogh
bash-4.1$ quota
(I couldn't copy the whole text after using "df" due to spam filter)
As an experiment, remove -module and see what happens. Or maybe put in an absolute path.
Behnam_M_
Thank you Steve
I simply tried to compile it using
bash-4.1$ ifort FAST_Mods.f90 -o FAST_Mods.o
And here are the errors I get. Could you please tell me what are these errors related to?
It looks as if module NWTC_Library, which you didn't supply, also has a definition of type OutParmType, which is conflicting with the one in module Output. As an experiment, you could try replacing the line:
USE                             NWTC_Library
with
USE                             NWTC_Library, notused=>OutParmType
and see what it does.
