29421 Discussions
error #7416: Fortran 2008 does not allow this intrinsic procedure. [THIS_IMAGE]
AShte
$ mpif90 --version ifort (IFORT) 14.0.0 20130728 Copyright (C) 1985-2013 Intel Corporation. All rights reserved. $ mpif90 -c -coarray=distributed -free -fPIC -stand f08 -warn all -warn stderrors cgca_m2alloc.f90 cgca_m2alloc.f90(97): error #7416: Fortran 2008 does not allow this intrinsic procedure. [THIS_IMAGE] write (*,'(a,i0)') "ERROR in cgca_as: image: ", this_image() -------------------------------------------------^ cgca_m2alloc.f90(100): error #6477: Fortran 2008 does not allow this statement or directive. error stop -^ The relevant code fragment is: 96 if (errstat .ne. 0) then 97 write (*,'(a,i0)') "ERROR in cgca_as: image: ", this_image() 98 write (*,'(a)') "ERROR in cgca_as: cannot allocate coarray" 99 write (*,'(a,i0)') "ERROR in cgca_as: error code: ", errstat 100 error stop 101 end if If I remove "-stand f08 -warn stderrors", then the code compiles fine. This is clearly wrong. What's going on? Thanks Anton
Lorri_M_Intel
Yes, this is a bug; we were incorrectly giving standards warning for F2008 features.  You can keep your -stand f08 switch, but remove the  warn stderrors one, which turns standards warnings into errors (and stops the compilation process).
               --Lorri
