29651 Discussions
error # 8227 type - dynamic type pointer mismatch - Fortran V12.0
Terry_Gerald1
Encountered an error wihen using a "derived" type.
I searched the web for discussions cocerning this error.
Found an example that reproduces the same error with Intel Fortran 12.0 I am getting with my code -
http://fortranwiki.org/fortran/show/Factory+Pattern
module connection_mod
type CFactory
private
character(len=20) :: factory_type
class(Connection), pointer :: connection_type
contains
procedure :: init
procedure :: create_connection
end type CFactory
type, abstract :: Connection
contains
procedure(generic_desc), deferred, pass(self) :: description
end type Connection
abstract interface
subroutine generic_desc(self)
import :: Connection
class(Connection), intent(in) :: self
end subroutine generic_desc
end interface
!! An Oracle connection
type, extends(Connection) :: OracleConnection
contains
procedure, pass(self) :: description => oracle_desc
end type OracleConnection
!! A MySQL connection
type, extends(Connection) :: MySQLConnection
contains
procedure, pass(self) :: description => mysql_desc
end type MySQLConnection
contains
subroutine init(self, string)
class(CFactory), intent(inout) :: self
character(len=*), intent(in) :: string
self%factory_type = trim(string)
self%connection_type => null() !! pointer is nullified
end subroutine init
function create_connection(self) result(ptr)
class(CFactory) :: self
class(Connection), pointer :: ptr
if(self%factory_type == "Oracle") then
if(associated(self%connection_type)) deallocate(self%connection_type)
allocate(OracleConnection :: self%connection_type)
ptr => self%connection_type
elseif(self%factory_type == "MySQL") then
allocate(MySQLConnection :: self%connection_type)
end if
end function create_connection
subroutine oracle_desc(self)
class(OracleConnection), intent(in) :: self
write(*,'(A)') "You are now connected with Oracle"
end subroutine oracle_desc
subroutine mysql_desc(self)
class(MySQLConnection), intent(in) :: self
write(*,'(A)') "You are now connected with MySQL"
end subroutine mysql_desc
end module connection_mod
program poly
use connection_mod
implicit none
type(CFactory) :: factory
class(Connection), pointer :: db_connect => null()
call factory%init("Oracle")
db_connect => factory%create_connection() !! Create Oracle DB
call db_connect%description()
!! The same factory can be used to create different connections
call factory%init("MySQL") !! Create MySQL DB
!! 'connect' is a 'class' pointer. So can be used for either Oracle or MySQL
call factory%final() ! Destroy the object
write(*,*) 'Finished'
end
This example shows more errors. How about you show us an example of your code that gets just the particular error? In the program you posted, the compiler complains earlier. I'll have to study this to see if the errors are warranted.
Terry_Gerald1
Steve,
My code is significantly longer - thats why I posted the above code. The error appears to be the same.
The pertinent error isin function"create_connection"
where we declared :class(Connection), pointer :: ptr
I have a similar construcrt in my code where I attempt to set a "base class" pointer to a "derived class" object.
I get :
error #8227 "The type of the target is not a dynamic type of the pointer [PTR]"
If you want my actual code - I guess I will have to edit it down.
You should be able to edit it down to something small.
Terry_Gerald1
Code snippet follows:
module mesh_mod
type :: node_type
real :: x,y,z
end type node_type
type :: mesh_type
type(node_type), allocatable :: nodes
class(integrator_type), pointer :: integrator
contains
procedure integrate => mesh_type_integrate
end type mesh_type
type, abstract :: integrator_type
contains
procedure(interface_integrate), deferred, pass(this) :: integrate
end type integrator_type
abstract interface
subroutine interface_integrate(this, mesh, time)
import :: integrator_type, mesh_type
class(integrator_type) :: this
type(mesh_type), pointer :: mesh
real :: time
end subroutine interface_integrate
end interface
type, extends(integrator_type) :: CGM_type
contains
procedure :: integrate => CGM_type_integrate
end type CGM_type
type, extends(integrator_type) :: DGM_type
contains
procedure :: integrate => DGM_type_integrate
end type DGM_type
contains
function create_mesh(solver) result(mesh)
character(len=*) :: solver
type(CGM_type), pointer :: cgm
type(DGM_type), pointer :: dgm
allocate(mesh)
select case(solver)
case('CGM','cgm')
! NOTE A: First attempt:
!allocate(CGM_type::mesh%integrator)
! NOTE B: Second attempt
!allocate(cgm)
!mesh%integrator => cgm
! NOTE C: Third attempt
integrator => integrator_create('CGM')
mesh%integrator => integrator
case('DGM','dgm')
! NOTE A:First attempt
!allocate(DGM_type::mesh%integrator)
! NOTE B:Second attempt
!allocate(dgm)
!mesh%integrator => dgm
! NOTE C:Third attempt
integrator => integrator_create('DGM')
case default
nullify(mesh%integrator)
end select
end function create_mesh
subroutine CGM_type_integrate(this, mesh, time)
class(CGM_type) :: this
real :: time
! Do mesh node mechanics
end subroutine CGM_type_integrate
subroutine DGM_type_integrate(this, mesh, time)
class(DGM_type) :: this
real :: time
end subroutine DGM_type_integrate
subroutine mesh_type_integrate(this, time)
class(mesh_type) :: this
real :: time
! NOTE D: Should work - compiler complains
!integrator => this%integrator
!call integrator%integrate(this, time)
call this%integrator%integrate(this, time)
end subroutine mesh_type_integrate
function integrator_create(integrator_name) result(integrator)
character(len=*) :: integrator_name
nullify(integrator)
select case(integrator_name)
case('CGM','cgm')
allocate(cgm)
integrator => cgm
case('DGM','dgm')
allocate(dgm)
integrator => dgm
case default
nullify(integrator)
end select
end function integrator_create
end module mesh_mod
program poly
use mesh_mod
type(mesh_type), pointer :: mesh => null()
real :: time = 1.0
mesh => mesh_create('CGM')
call mesh%integrate(time)
end
I labelledproblemconstructs with "NOTE A, NOTE B, NOTE C and NOTE D"
Thanks - I'll take a look at this.
