29407 Discussions
error #8550: An OpenMP* ATOMIC capture-statement is expected
Petros_A_1
I am trying to get an atomic read out of a global module variable to be returned by the function. A small example is:
integer(c_int) function get_mag(mag) bind(C, name="get_mag")
#ifdef DLL
!DEC$ ATTRIBUTES DLLEXPORT :: get_mag
#endif
use VOL, only: x_g, y_g
implicit none
real(c_double), intent(inout) :: mag
doubleprecision :: x, y
integer :: num
num = 1
!$omp atomic read
x=x_g(num)
!$omp atomic read
y=y_g(num)
mag=hypot(x, y)
get_mag=0
end function get_mag
I get an error "error #8550: An OpenMP* ATOMIC capture-statement is expected" on both atomic reads. I don't know what I'm doing wrong.
Module VOL has simply:
double precision ::  x_g(10000), y_g(10000)
I have the ifort version "Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.2.181 Build 20160204"
Thanks in advance
jimdempseyatthecove
!$omp atomic read
x=x_g(num)
!$omp end atomic
Jim Dempsey
Petros_A_1
jimdempseyatthecove wrote:
!$omp atomic read
x=x_g(num)
!$omp end atomic
Jim Dempsey
I get the same exact error... And according to the OpenMP standard, it shouldn't require an end directive...
jimdempseyatthecove
As shown above, it would appear that you found a compiler error.
As an alternative, use !$omp flush(x_g(num)) before the read (same with y_g(num)).
Jim Dempsey
Petros_A_1
Flush didn't seem to work either. It only accepts !$omp flush(x_g) and it gives the same error. For now, I have converter it into a critical section.
Just for complete information, I tried also with v15.0.0.090 and v13.1.3.192, both give the same error.
Xiaoping_D_Intel
Can't reproduce the error with your code. Which compiler options are you using? I am using "ifort -c -qopenmp -fpp test.f90".
Xiaoping Duan
Intel Customer Support
Petros_A_1
Xiaoping Duan
I use:
ifort -align -zero -fpp -openmp -O3 -traceback -implicitnone -fPIC
I have also tried with
ifort -fpp -openmp -traceback -implicitnone
Same error. I think under Linux it's -openmp, not -qopenmp.
Xiaoping_D_Intel
Still can't reproduce the error using the same command line. If you are using 16.0 compiler there must be message like:
ifort: command line remark #10411: option '-openmp' is deprecated and will be removed in a future release. Please use the replacement option '-qopenmp'
Would you please attach a complete test case including module source and the function source which can be compiled to reproduce the error, or submit it through Intel Premier Support?
Xiaoping Duan
Petros_A_1
Xiaoping Duan
Dear Xiaoping, you are right. I was compiling with version 13 all the time. when I actually switched to v16 the error was removed and I got the warning about the deprecated option (which I fixed). Thanks!
