29376 Discussions
error LNK2001: unresolved external symbol _fltused
krishnabc
I am having the above error and several others (also shown in the attachment) when compiling one of the projects in DEBUG mode. However, the compilation in RELEASE mode goes well.
Appreciate your suggestions.
VS 2008, IVF 12 update 3, Win 7 32 and 64 bit OS.
Thanks in advance.
Krishna
mecej4
This problem usually arises when an attempt is made to link one or more objects and/or libraries with recorded dependencies on LIBCMT.LIB (usually the result of using /MT as a compiler option) but a C-runtime library such as MSVCRT.LIB is used instead (which is pertinent to compiling with /MD).
Resolution: make sure that all objects and user libraries that participate in the link are compiled with the same /Mx option. Failing this, produce a linker map and pin down the specific objects/libraries that call out the missing symbols.
krishnabc
Thank you very much mecej4. Finally, I resolved it.
